RV.Net Open Roads Forum: Tow Vehicles: Ram 3500 issue
Search only in Tow Vehicles
 > Ram 3500 issue
Page of 5
Cummins12V98
on the road
Posted: 08/27/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
"Taking off from a stop and turning it acts like it's in 4 wheel drive"
Have you aver changed your rear axle gear lube???
Jerry thanks for the kind words!!!
My rear grabbed like in 4wd and it was the OE lube was shot. Schlage to AMZ/OIL 75-110 Severe Gear and my troubles vanished.
Don't use OE lube it's JUNK and VERY expensive.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ShinerBock
LVTX
Posted: 08/27/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
My truck does the same depending on how hard I am turning. For me, it is the torsen style LSD (anti-spin) locking up because the tires are spinning at different rates so it locks up the worm gear(like it should). Torsen LSD's generally abruptly lock up as opposed to the gradual lock up of clutch style LSD's. It does not do it in my brothers truck which is like my 2014 2500, but without the anti-spin diff. If I turn too sharp and too fast unloaded, it will chirp the back tires which is more pronounced due to my oversized tires.
* This post was edited 09/08/21 06:35am by ShinerBock *
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
bolljl
Fulltimer
Posted: 08/27/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I had same issue was told that’s normal. Plus, extreme front tire wear. Went two different dealers and wrote to Dodge customer Service sorry can’t help you. It got so bad that when just turning corner even without rv steering wheel pulled back and forth. Took it to third dealer and they replace steering gear and pump.
So far problem solved.
2015 RAM LongHorn 3500 Dually 4X4 CUMMINS
2013 Lifestyle LS35SB, MORryde IS System
AIRSAFE, Air Hitch
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/27/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Extreme front tire wear is the factory tow in setting. To much toe in. Ron should have replied to that! He seldom misses the issue!! RON!
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it!
Cummins12V98
on the road
Posted: 08/27/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
For my DRW my frame and axle guy said OE spec of 1/4” toe is WAYYYYY too much. Set to 1/64” toe and all your outer edge “stepping” woes will go away.
Rotate front tires ONLY by moving tires side to side leaving rotation the same. Tires need to be separated from rims to do so.
TxGearhead
Posted: 08/29/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I bought 5 quarts of Valvoline full synthetic 75w-140 gear oil. Will let the dealer change it when I'm there next week for a oil change.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Cummins12V98
on the road
Posted: 08/29/21 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
I would return it. That’s wayyyyy too heavy. Look in your manual.
I use AMZ/OIL SevereGear 75-110 because I tow 35k combined. The Dana axles used the heavy spec towing heavy.
TxGearhead
Posted: 09/08/21 05:44am Link  |  Quote  |  Print  |  Notify Moderator
You have a point. Manual says 75w-90. Guess I will go with that and see if it helps.
Thanks for your input.
4x4ord
Alberta
Posted: 09/08/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it is coming out of 4wd? Jack up one front wheel and see if it spins freely. Should Ram front hubs free wheel when in 2wd? (ie Does Ram use a auto lock hub like Ford or a constant locked hub like GM?)
2021 F350 SRW Platinum short box 4x4.
B&W Companion
ShinerBock
LVTX
Posted: 09/08/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Ram's 4wd system disengages the front axle completely when not in use unlike the Ford system which keeps the front axle spinning at all times, but locks the hubs when power to the wheels is needed.
Page of 5
 > Ram 3500 issue
