RV.Net Open Roads Forum: Towing: Rotating Trailer Tires
Search only in Towing
Open Roads Forum  >  Towing
 > Rotating Trailer Tires
Vintage465
Prunedale CA.
Posted: 08/26/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
I was getting some maintenance on my 4 GoodYear Endurance Tires. I told them to make sure they balanced and rotated them. The attendant said he would, but for my information he told me trailer tires don't need to be rotated. I assured him they do need to be rotated because only one set of tires(front axle)trails the tow vehicle on turns and the other one(rear axle)skids to some degree. So my question is; going forward, the front axle is the the trailing axle and the rear is the skidder, right? And in reverse the rear would be the trailing(even though it's leading now)and the front axle is the skidder....right? All this is assuming the WD hitch is set up so the front axle will have slightly more weight on it.
Thanks!
* This post was edited 08/26/21 08:08pm by Vintage465 *
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
blt2ski
Kirkland, Wa
Posted: 08/26/21 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Correct. Reality for most of us, we will blow up the tires from age WELL before they are worn out.
BUT, if you do a lot of slow speed manuvering, backing turning etc, you will notice this sooner.
I did not notice this on with set of majority worn tires on my rv trailer. My equipment trailer which does not spend a lot of time on the freeway, one noticed the accentuated rear wear. When you literally jack knife the trailer half a dozen times in 40-50 miles of during, getting a bobcat, trackhoe or equal on and off if it daily, park it back at shop. This WILL be an issue. Did I notice this on tv tires? Yes after 50k miles vs 10-20 on equipment trailers.
You decision.
I also have never balanced a trailer tire, not dual wheels.
Personal choice on that on IMHO.
Marty
Check RV.Net Blogs at: blog.rv.net
Vintage465
Prunedale CA.
Posted: 08/26/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
You decision.
Marty
I have them balanced because at America's Tire/Discount Tire, you pay balancing as it is included in the mounting and also in the regular rotating. So since I paid for it I make sure they do it
dodge guy
Bartlett IL
Posted: 08/27/21 05:02am Link  |  Quote  |  Print  |  Notify Moderator
No, both axles scrub evenly. Unless you have torsion axles and don’t have the trailer setup level. And they don’t stay on the trailer long enough to go bad, they should be replaced every 5 years.
So balance is all that is needed.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
valhalla360
No paticular place.
Posted: 08/27/21 05:48am Link  |  Quote  |  Print  |  Notify Moderator
This.
The trailer rotates about the center between the axles. But really most RVs spend 99% of their miles going down the road where there is negligible scrubbing. Far less wear than a car in city driving.
As mentioned, you almost always age out a set of tires long before they wear out...so there is no harm in rotating them but I wouldn't spend money on it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Mike134
Elgin, IL
Posted: 08/27/21 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I wear mine out before they age out so I rotate and balance. The front axle of my camper has a bit less camber then the back (a replacement) so I rotate.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
BB_TX
McKinney, Texas
Posted: 08/27/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Never rotated and never any uneven wear.
Timmo!
Oregon
Posted: 08/27/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Fact #1: When a tire is driven, the pressure and flexing motion circulate the internal oils through the rubber. These oils lubricate the internal rubber and keep it from drying and stiffening. So tires that are used less are often more vulnerable to aging effects.
Fact #2: Oxidation of rubber occurs much faster under high heat than low heat.
Fact #3: During rubber manufacturing process, each passenger tire require 5 gallons of butadiene and styrene oil and another 2 gallons of oil to generate the energy to manufacture said tire. For a total of 7 gallons of oil, commercial truck tires require 22 gallons of oil.
Like most of you, my TT spare tire is on my back bumper, wrapped in a black tire cover and receives direct sunlight most of the day. I recently replaced my TT's five tires and the unused spare tire looked remarkably worse than the 4 used tires. Hmmm, guess there is some truth in Fact #2.
IMO, if my spare tire was included in a tire rotation plan, the spare tire would age slower.
I have joined the rotate tire camp and we'll see what happens. Each spring I remove my tires and grease the wheel bearings and inspect the brakes. So, starting next spring my plan is to rotate TT tires using the "rearward cross" rotation pattern. Gotta take the tire off to grease the bearings, so why not? No harm, no foul.
Let's Go Brandon!!!!
Tim & Sue
Hershey (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 35.7 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
Cummins12V98
on the road
Posted: 08/27/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
NEVER have rotated any of my RV tires and they have worn evenly. Biggest thing a person can do is have as close as possible axle weights.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Sandia Man
Rio Rancho, NM
Posted: 08/27/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Your rig your tires, no need to validate your choices. We always balanced new TT tires but never had them rotated, in fact never would return back to Discount Tire until it was time for replacement 5 years later. Although rare, if a TT tire had a minor leak or other issue I would pop it off and just throw it on truck to take to Discount Tire.
We always used higher quality ST tires on our rig with never a blowout or even a flat, none the less we would change them out like clockwork every 5th year. We average 5K miles yearly so they had plenty of tread left, with often reported ST tire issues, our TT tire replacement might be premature, but you can't put a price on the peace of mind a new set of rubber delivers.
