RV.Net Open Roads Forum: Full-time RVing: Fiberglass polishing
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Fiberglass polishing
luvmydogs
Ct
Posted: 08/26/21 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
We have a fiberglass travel trailer. One side seems to have kept its shine the other seems to have oxidized some. Is there something to special to use to get its shine back or do I have to polish and rub with regular stuff? Any advice?
rexlion
Broken Arrow OK
Posted: 08/27/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
After washing thoroughly, applying a couple coats of Zep floor wax will make it shine like new.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
LouLawrence
Traveling the US!
Posted: 08/27/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
You can't "restore" it. You have to either sand and paint it or figure out something that will make it look good for awhile.
JimK-NY
NY
Posted: 08/28/21 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I am a fan of the ZEP floor wax system, but first you need to prep the surface. I recommend using a Scotch kitchen scrub sponge with a very mild abrasive, either Bar Keepers Friend or Bon Ami. It will be a slow process because you need to go over every square inch with light scrubbing. Odds are there is still some old wax on the RV. You also need to scrub that off using a dilute ammonia solution. If you take your time with the surface prep, you can then apply ZEP finish that will last and last. Mine is still going strong from 2015.
The Zep finish is easy to apply. You can use a sponge floor mop, but I did mine by hand. Lightly dampen an approximately 10 inch square rag and apply a thin coat. Make sure you do not get any drips and sags. The first coat or two will not look good. You will need to apply at least 4 thin coats. The Zep finish will prevent further oxidation, will give the RV a moderately good shine, will prevent the black streaks, and will last for years. Zep works so well I barely have to wash my RV. I do wash it about once a year and apply another thin coat of Zep.
Again, surface prep is important. If the surface prep is skipped or done poorly the Zep surface can flake off after a few months or years.
