RV.Net Open Roads Forum: Adding scissor jacks for side to side leveling
 > Adding scissor jacks for side to side leveling
Page of 6
Boon Docker
Posted: 08/30/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure you bend your beam carefully or suffer the gravitational consequences. [emoticon] [emoticon]
ajriding
st clair
Posted: 08/31/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you have a twin axle trailer?
You also said jacks, not stabilizers. Jacks can and will and are made to lift the trailer. We are not talking about stabilizers.
I lift the frame at the axle point. I used a bottle neck hydro jack, not scissors jack. For a dual axle I put the jack between the axles under the frame if possible, or as close to the axle as I can get if in front or behind the axles. This does not put any new stresses on the frame and lifts the frame at about where the axles hold the frame anyway. Or easier to just lift the axle, not the frame. One axle is fine and will not damage the frame, body, or door or bend anything. Your trailer goes on one axle all the time driving it around (one of 4 wheels unloaded anyway).
I do this only in extreme situations if I have to park off level and my other leveling method is too short.
Parking on ramps or boards or rocks is much preferred to me. It is easier than crawling around with a jack.
Posted: 08/31/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
OP is talking about installing a leveler system, not mucking around with a bottle jack every time he parks the camper.
2017 Heartland Torque T29
vtraudt
Brighton, MI
Posted: 09/01/21 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
I was under there yesterday; the process is certainly easy (lifted one axle at a time, but board under. But it is combersome.
If planning to keep trailer ON WHEELS, then lifting axle is easier.
If NOT using wheels, I would lift the FRAME and put jackstand under frame.
I will use this method when 'driving back/forth' (potentially several times) is not an option. And certainly in my driveway (car/trailer under angle, incline and more than 4 inches to level sideways.
For axle lifting, I am planning to make a "U" shaped top for my bottle jack. For the 'frame lifting', a square platform (with replaceable wood on top).
BB_TX
McKinney, Texas
Posted: 09/01/21 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
My simple brain looks at the whole frame bending thing in a much more simple way. An RV trailer sitting on dual axles is going to have 6-8-10’ hanging out past the rear axle. The weight supported by and spread over four suspension points on each side. And the weight of the RV is going to cause that rear cantilevered overhang portion to sag downward.
Now put jacks near the rear of the trailer and raise those jacks to level the trailer and that new upward force at the rear is going to start taking weigh off the suspension, and instead transfer that weight to the rear of the frame. Now the center of the frame with less support will tend to sag downward due to the transfer of points supporting that weight.
Lift at one rear corner more than the other and the frame will tend to twist.
What is wrong with that simple view point? Doesn’t need a discussion of gravity.
* This post was edited 09/01/21 09:07pm by BB_TX *
JRscooby
Indepmo
Posted: 09/02/21 04:51am Link  |  Quote  |  Print  |  Notify Moderator
I can't stand under the "potentially several times". Once to see how much lift is needed, the 2nd time to put it on the ramp. You're done.
If I needed ramp in my drive, I would bolt it together, and leave it home. Of course, if I need 4 inches when I get home from last trip, I assume I will need 4 this time.
(I have a pair of rubber mud flaps, with a 4X4 bolted to 1 end, and a 2X4 spaced right, and bolted to other side. They stay in the thinly graveled drive. I back in until trailer goes over the 2X and stops against 4X. Chocks on both sides of both wheels, the jack goes down on the 6 inch long 2X6. With the tires sitting on rubber, no need to get weedeater close to tires.
Thank you.
vtraudt
Brighton, MI
Posted: 09/02/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
You don't have to stand under anything if you don't want to.
But if 'back/forth' is not an option (as stated), it simply IS not an option.
Hence, an alternative way is needed.
vtraudt
Brighton, MI
Posted: 09/02/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
There is nothgin wrong per se with the simple few: the rear overhang when on wheels is bending the frame down under its weight/mass (gravity does it, and in addition, acceleration (from bumps) does it too.
Bend lifting up, it is bending the frame up by (simplified) the same amount.
Regarding uneven "twisting". If you drive through a pothole with one side of camper only, the same 'twisting' of the frame will occurs as if you lift on one corner only.
How much (in accurate terms and amounts) bending down (gravity, acceleration from bumps) and up (lifting, bumps) takes place is difficult to calculate (too many unknown variables).
Fact is: our trailers bend A LOT already (mostly down)
Page of 6
