RV.Net Open Roads Forum: Towing: TPMS question?
Search only in Towing
Open Roads Forum  >  Towing
 > TPMS question?
RAllison
Millersburg,ohio
Posted: 08/27/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I have a 38' Keystone Outback being pulled by a dbl cabbed 6' bed pickup. Is there a distance I need to be aware of for the signal to reach the receiver. Getting ready to buy a Tpms system but can't really find out if there is a max distance. Thanks
RoyF
Fayetteville Arkansas
Posted: 08/27/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I tow a 35' fifth-wheel with a long-bed crewcab. My TST sensors all reach the receiver. But before that I used a different brand (can't remember which one), and it needed a booster in the trailer.
bob213
Fresno, CA
Posted: 08/27/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
A booster(repeater) is included with the TST system according to this:
Booster
ktmrfs
Portland, Oregon
Posted: 08/27/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Booster
same with tire minder, booster mounts on the tongue,
2011 Keystone Outback 295RE
dodge guy
Bartlett IL
Posted: 08/27/21 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Most of the systems come with a repeater that you wire into 12V. On a trailer you could put it in the front storage compartment and this would be perfect to transmit it to the display. Most of the systems being sold now come with the repeater.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
QCMan
Independent Republic of Horry
Posted: 08/27/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
TST comes with a repeater. Don't know if I need it as the unit is not long but mounted it to the inside of my propane cover. I like that only the display goes to sleep if there is no movement. We bring the display into the trailer at night and it becomes our outdoor thermometer. Just touch the display unit and you instantly have readouts on the tires. If you can get short enough metal valve stems onto your rims I would suggest the pass thru sensors.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
dodge guy
Bartlett IL
Posted: 08/27/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
On my 36ft class A I needed it just for the MH itself, the sensors aren’t strong enough to transmit to the unit. My rear axle is only 25ft from the mounting location of the display unit.
Blazing Zippers
North Idaho
Posted: 09/06/21 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
I placed the booster on the battery box in the front of the trailer--connected to the left clearance light of the trailer. We always run with the lights on, so when the lights are on, the booster is on.
Taa Daah! Works great.
fj12ryder
Platte City, MO
Posted: 09/07/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I have the 507 TST system, and bought it before they started supplying the booster as part of the purchase. I pull a 38' 5th wheel toyhauler and it reads the sensors without an issue. But YMMV.
Howard and Peggy
"Don't Panic"
dodge guy
Bartlett IL
Posted: 09/07/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
FWIW, on our last trip I had my daughter wait at the dump station across the road. As I got in after dumping I noticed the TPMS display was showing the toad. The car was about 100ft away. So the repeater works great. Without the repeater I don’t get the rear tires of the MH which are closer than the repeater.
 > TPMS question?
