RV.Net Open Roads Forum: Class C Motorhomes: Fuel leaking from within the generator
 > Fuel leaking from within the generator
Whataday
Reno
Posted: 08/27/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I parked my RV on a slant (forward down) and the next morning noticed a major leak from below the generator. I lost about 30 gallons of gas, before I finally put it in neutral and coasted it down the driveway to a more level spot. The leak continued. It seams as though once I lost enough gas from the main tank to the generator, the leak stopped (started with a full tank and now have 1/4). I looked on the back side of the generator to see if there was a cracked hose and the hose going into the generator looks good. Now I'm faced with opening the back of the generator to see what may be going on inside. It looks pretty tricky to unbolt the metal housing that the generator sits in, to get access to the back panel of the generator itself. Any help would be appreciated.
2007 Forest River-SunSeeker 4000 Onan Generator
Posted: 08/27/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
It seems virtually impossible for fuel to drain from the main tank via the generator fuel line. Generator is not (well shouldn't be and not in my experience) gravity fed.
Shouldn't be possible to lose significant fuel out of the tank unless there's a hole in the tank itself. All the fuel pickups come out the top of the tank. Unelss a full line literally was cut and was able to pull a siphon until it emptied the tank.
2017 Heartland Torque T29
theoldwizard1
SE MI
Posted: 08/27/21 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel leaking from a carburetor almost always means a colored needle valve or sunk float. Yes, the carburetor needs to be removed.
Rick Jay
Greater Springfield area, MA
Posted: 08/27/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Whataday,
WOW!!! THAT is a LOT of fuel to leak out.
I'm not sure if your Onan 400 shares a similar design to our Onan Marquis Gold 7kWatt (also gas). I'm going back a number of years here, so hopefully my memory isn't too far off. I can tell you that originally my generator had two fuel filters: one right on the generator and another before the generator fuel pump. It was kind of strange, but that's the way they did it.
Well, getting the fuel lines on the filter on the generator tight enough so they wouldn't leak was a bit of a trick. It was behind the air cleaner housing. If you completely removed the air cleaner housing assembly, you could generally get things tight enough. But if you tried to take a shortcut and not remove the air cleaner assembly, you couldn't get the connections tight enough and it would eventually vibrate loose and leak. I noticed mine leaking one time. This was a couple of weeks after I did the fuel filter change. It didn't leak immediately after I changed the filter.
When I went to the local Onan parts distributor, he sold me a "new" filter kit. It only had the one filter that went down by the fuel pump and a little doodad (technical term) which permanently replaced the filter mounted on the generator. It was a short length of tube which had six sides (like a nut) so that it could easily be tightened with the air cleaner assembly in place. Apparently, the leaking was a very common problem, so they removed one of the filters from the system and replace it with this new part. Since this new "doodad" didn't have to be serviced, it minimized that leaking issue once it was installed properly.
Here's a link which talks about the Onan gas fuel filters. Again, this was for the Onan Marquis Gold generators.
Again, I have no idea if your 4000 series is similar, but if it is, perhaps that's the problem. Check to see if there is a filter mounted on the generator and if it's leaking fuel, or looks like the source of the leak. Perhaps your generator never got the update kit.
Good Luck,
~Rick
* This post was edited 08/27/21 04:25pm by Rick Jay *
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (24-Angel since 2008), 1 girl (20), 2 boys (21 & 18).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
SJ-Chris
San Jose, Ca
Posted: 08/27/21 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
That is a very dangerous situation...take it very serious!
The fuel like going to the generator I believe *IS* gravity fed. I believe this because when you change the fuel filter you have to pop off that fuel line and it immediately starts leaking gas and you need to plug it while you change the fuel filter.
It stops leaking at 1/4 tank, because that's as low as your generator can draw gas from the main tank (BY DESIGN).
If you are lucky, the fuel line is leaking at or before it gets to the fuel filter. That might be an easy fix.
Do you see clamps of some sort where the fuel line connects to the fuel filter. If staring at the generator, the fuel line can be found outside the generator coming in from the left side.
Do you see gas in the bottom tray of the generator?? If so, perhaps it is leaking from inside the cover somewhere.
Since your generator wasn't running, it is a gravity fed issue and should be leaking somewhere before the fuel pump.
-Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
bgum
South Louisiana
Posted: 08/27/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds as though the fuel flowed until it got down to the bottom of your fuel pickup tube in the tank. If so there are several ways this can occur. It appears one of your readers has ruled out all possibilities which means it just didn't happen.
I would add some fuel and level the rig. At that point turn everything off and see if it leaks. Also listen at the generator to hear if a pump or small motor is running.
Posted: 08/27/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I stand corrected, if the generator fuel line pickup is gravity out of the vehicle’s main tank.
But since you don’t believe my post bgum, tell us where the fuel is coming from then please.
* This post was edited 08/27/21 02:59pm by Grit dog *
Rick Jay
Posted: 08/27/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I don't believe the fuel line is a gravity feed. I say this because I believe the pickup tube comes out the top of the gas tank. I know it does on my rig (Class A, so it might be different.)
That said, it IS a siphon issue. If there is gas in the line and you open the line (or a leak develops), the siphoning action will allow the gas to continue to flow until either the siphon is broken or the level of gas drops below the pickup tube. Which will also break the siphon action.
Please be careful as your troubleshoot this problem. Make sure all of the leaked gasoline is cleaned up before you try to start the generator.
Good Luck,
~Rick
SJ-Chris
San Jose, Ca
Posted: 08/27/21 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck,
~Rick
I *strongly* recommend you have a fire extinguisher next to you while troubleshooting.
My impression is that most of these fuel lines from the gas tank are physically connected to the RV gas tank at the 1/4 level and therefore they will stop allowing gas to the generator anytime the tank dips below 1/4 full. Perhaps I'm wrong, but that's the way I've always understood it. (...and of course different RVs can be hooked up different ways)
Good luck!
Chris
sch911
Rochester Hills, MI
Gravity feed or not doesn't matter. When parked on a angle. If the carb float is sunk or needle and seat are stuck open the fuel can syphon right out of the tank. Open up the generator remove the carb and re build it. Or take it to someone who can.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
