RV.Net Open Roads Forum: A/C locking up in 1984 class c
 > A/C locking up in 1984 class c
PlatinumSky
Nebraska
Posted: 08/27/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
I recently inherited a 1984 Kingston Midas camper, My great-grandparents were the previous owners and they take such good care of everything that the majority of the vehicle is effectively brand new. A couple of other relatives were taking care of it, and didn't have the time to perfectly care for the vehicle so I've been spending my time getting everything back and working order since it has such sentimental value to me. Fixed a bad fridge heating element, repair the water heater ignition, repaired the generator, etc. The only issue that I have now is that the air conditioner appears to run for a short period of time, it does pump out cold air, then within a few minutes, usually less than 10, the compressor locks up and then within seconds the circuit breaker trips. The fan is still running when the compressor locks up and there isn't any change in sound right up until the moment that it locks up or turns off. The odd thing is that when I take off the cover on top of the RV and hook up my AC manifold, It runs at the standard pressures for r22 refrigerant, comes down to about 60 PSI on the suction port, then equalizes about 85 psi. The part that's making it so hard to diagnose is that anytime I take off the cover and run the air conditioner, it just keeps running it doesn't stop, then as soon as I put the cover back on and try running it again it locks up and trips the breaker. Since the problem only happens when the unit is fully assembled I have no idea how I'm supposed to diagnose this issue. It blows nice cold air, even though there's a couple of dings here and there from bugs on the condenser it has plenty of air flow, The filters on the inside have been cleaned and have plenty of air flow as well, and the pressures I'm reading with my manifold seemed to match up with what everybody else seems to agree to be standard operating pressures for r22 AC systems. Forgive me if this is the wrong form to post in and I will immediately move it, in the meantime here's a picture of the manifold gauge hooked up to the unit, https://photos.app.goo.gl/1VUzC4gBb7TPGF8e6
And another picture with the name plate for the AC unit. https://photos.app.goo.gl/VCD6eMwaaemyo8AK8
If any of this isn't allowed in the forums I apologize and I'll remove immediately, this camper just has a lot of sentimental value because it's been around ever since my parents were kids, and I still hear stories about how my mom was chasing after my great grandparents in the camper when she was a kid.
* This post was edited 08/27/21 12:25pm by an administrator/moderator *
dedmiston
The West
Posted: 08/27/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I fixed the link for you.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
okhmbldr
oklahoma city
Posted: 08/27/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
How are you powering the A/C? Generator? House Power? If you're using an extension cord for power you might be using one that's a little to small. Extra heat will build up and shut off the compressor, then trip fuses. Heavy duty cords are best. And good luck with this old gal.
agwill
enosburg falls, vt
Posted: 08/27/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Those older AC units have oil ports on motor that need to be oiled on both sides. Take cover off and check for little oil caps on either side of the motor.
al
katysdad
Virginia
Posted: 08/27/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
check your voltage at compressor. low voltage will overheat a compressor and cause the thermal overload in the compressor to trip.
Dodge Ram 3500 DRW Diesel
PlatinumSky
Nebraska
Posted: 08/27/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I've ran it from both a 30 amp RV outlet as well as the built in Onan 4000 series generator, same results both times. The ground probe on my multimeter broke so I don't have a way to check the voltage right now but I'll do so once my new probes come in the mail.
PlatinumSky
Nebraska
Posted: 08/27/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I found and oiled those on the blower motor, it spins really smooth by hand when the cover is off and it keeps spinning even with the compressor stopped so I didn't think it was part of the problem but I'll take a closer look at it as well.
PlatinumSky
Nebraska
Posted: 08/27/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Once I get my new probes in the mail I'll check the voltage, the grounding probe on my multimeter broke so I'm waiting for a new one. I might be able to borrow a friend's who does some crazy stuff with radio transmitters.
Gdetrailer
PA
Posted: 08/27/21 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
The A/C is from 1984?
Time to replace it.
RV A/C units are factory sealed with zero refrigerant ports and were never intended to be serviced.
The fact you have ports, means someone has added ports and has been worked on before.
Not worth dropping money on a new compressor in an A/C unit this old which may have potential small leaks in the refrigerant lines (remember, someone did add ports for a reason).
Your not going to change "sentimental value" of the RV by replacing the A/C unit.
hypoxia
Arizona
Posted: 08/28/21 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Is there any chance the cover is blocking air flow through the condenser? That would cause those symptoms.
Jim
2007 Monaco Signature Noble III ISX 600HP
