RV.Net Open Roads Forum: Travel Trailers: On top
 > On top
Diamond c
West ky
Posted: 08/28/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Ok this may be a stupid question. I know people have to be able to get on top to work on the a/ c units and what not, bu5 just how much walking around can/should be done up there? Btw we have a 2020 38’ Keystone Outback.
BobsYourUncle
Calgary Alberta Canada
Posted: 08/28/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
I get up on my TT frequently to check things. I try to walk on the rafters instead of between them. After a while you can see where they are. Until then you can use a foot to feel where the rafters run.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Near DVNP, California
Posted: 08/28/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
I never walk on the roof unless required…which is seldom. Dangerous. Most work can be done on a good ladder.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
deltabravo
Spokane, WA
You can walk up there as much as you need to.
Some RVs have really thin roof decking, which will flex when you walk on them. A thin roof material will be easily noticeable when you get up there an start walking around.
What are the advertised specs of the roof decking thickness for your Keystone?
jdc1
Rescue, Ca
Posted: 08/28/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
The roofs ARE NOT built to walk on. 3/8" plywood is used as sheathing. Just go up, do the work and get off the roof.
NamMedevac 70
Reno
Posted: 08/28/21 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
When recoating my TT roof with liquid rubber roof I wore soft soul sneakers (yacht sneakers) and when down on my knees to work on AC, etc. for extended periods I used a thin 4x4 or 5 light thin piece of plywood to distribute my weight and used extension ladder for access to roof. Never any problems or leaks using this method. I do not weigh a ton. Hard rubber mat would also distribute your weight I would think. Cheers
kellem
Shenandoah valley,VA
Posted: 08/28/21 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Also have a 2020 Outback and I'm on the roof quite often for inspection.
The roof is domed and flimsy between the rafters so I find it best to crawl as to distribute weight more evenly.
I also wear crocs and knee pads.
Terryallan
Foothills NC
Posted: 08/28/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Actually it depends on your RV. "most" but not all, are designed to be walked on.. Especially the ones with a factory ladder.
If you are in doubt. Call the manufacturer of your camper. They will tell you in just a minute.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
deltabravo
Spokane, WA
Posted: 08/29/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Not All RVs have plywood that thick.
If it does have plywood that thick, it's BUILT TO WALK ON.
A lot of RVs I have been researching specifically state "full walk on roof" in their literature.
Making a blanket statement saying "The roofs ARE NOT built to walk on" is totally incorrect.
This is why I posted the details in my earlier post, shown here:
Outdoors RV and Northwood build full walk on roofs with 3/8" plywood.
They advertise them as full walk on roofs.
Diamond c
West ky
Posted: 08/29/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
I’m just wanting to get up there to wash and inspect. Probably will just barrow a tall step latter and stay off the roof .
 > On top
