RV.Net Open Roads Forum: Towing: Endurance Tires
Search only in Towing
Open Roads Forum  >  Towing
 > Endurance Tires
Charlie D.
E. Texas-Orange
Posted: 08/28/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
New camper has Westlake ST205/75R15 tires on it.
Going to replace them with Endurance. While checking prices I came across ST225/75R15 Endurance for $15.00 each more tire. Would you use 225 vs. 205?
Grand Junction Transcend 240ML
UVW 6285
Hitch 598
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
bob213
Fresno, CA
Posted: 08/28/21 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the clearance above and the space between the tires I don't see a problem.
larry barnhart
wenatchee. wa usa
Posted: 08/28/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
are load range E? I feel one is a D tire. Might be wrong but we bought the E rated endurance.
chevman
chevman
2019 rockwood 34 ft fifth wheel
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
time2roll
Posted: 08/28/21 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I stayed with 205. Capacity is greater than my GVWR. Been on several years, no issues.
675w Solar pictures back up
JIMNLIN
Oklahoma
Posted: 08/29/21 07:27am Link  |  Quote  |  Print  |  Notify Moderator
The trailer shows a 7495 GVWR = 1875 lbs per tire....
Dry weight says around 6265 = 1560 lbs per tire....
This = around 1200 lbs of CCC so most likely the trailer will weigh close to its 7495 lb max gvwr.
The Endurance ST 205/75-15 load D at 65 psi and a 2175 lb load capacity will give the trailer a nice 15% load reserve capacity. ?
Some tire dealers have excellent experience with trailer wheels tech and tires tech (matching pressures/load capacities/proper width/etc).......others ??.
For this trailer I would stick with the OEM sizes/load ranges.
edit ....jim
* This post was edited 08/29/21 08:15am by JIMNLIN *
Cummins12V98
on the road
Posted: 08/29/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Good call dumping the Chinese JUNK!!! You will be happy with the Endurance. If you up in Load range from D to E use the Load/inflation chart for your tire. Most likely you will be running 65psi the same as the D's.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 08/29/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
OP, this sure seems like something you can figure out without asking the Internet forums opinion…
But since you did, I’m not in the habit of tossing new tires in the garbage. I’d run them for a while.
Hope that helped! Lol.
2017 Heartland Torque T29
mooky stinks
Cicero,NY
Posted: 08/29/21 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
edit ....jim
Are you forgetting tongue weight deducts from axle weight? The 7500 GVW would be closer to 6500 on the axles.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
MFL
Midwest
Posted: 08/29/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with most posts above!
First thing, I'd run the Westlakes, for a couple years or so, depending on miles, and proper care.
Next thing...yes the Endurance is likely a better tire choice!
After deducting tongue wt, 6,500 is a close wt estimate on the tires. The OEMs have plenty of margin, fit the fender/wheel well clearance, a good fit for OEM wheels.
When time comes to replace the Westlakes, the Endurance, in the oem size, and D-rating, at 65 psi, is best option.
Jerry
deltabravo
Spokane, WA
Posted: 08/29/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
225s may not have enough clearance between tire and suspension or frame of the RV. I tried to switch to 225s and they were a no go.
A given size of Goodyear Endurance has a higher load and speed rating compared to the same size in other brands of tires.
I mention it in this video
 > Endurance Tires
