RV.Net Open Roads Forum: Fifth-Wheels: Macerator pump questions
 > Macerator pump questions
BarneyS
S.E. Lower Michigan
Posted: 09/02/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I think the reason you are seeing stuff still come out after more than one dump is because "stuff" gets into the corners when you just sit in one spot and are not moving around thus mixing the contents. The tank rinser does not reach them well enough - especially the corners on the same side of the tank as the rinse nozzle.
I found that while snowbirding in Florida for 18 years and staying in one spot for 3-4 months, I had to use the wand down the toilet hole about once a month to blast the stuff out after normally using the tank rinser every dump. It would take quite a while before the water ran clear too because the stuff packs quite tightly into the corners!
Here is the one that I use. It does a good job and shoots a powerful blast of water. I would use it down the toilet while emptying with the macerator.
Barney
* This post was edited 09/02/21 08:35am by BarneyS *
Not towing now.
laknox
Arizona
Posted: 09/02/21 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Barney. Frankly, unless we get some property, we're likely not going to sit =too= much. :-) If it gets much worse, I'll probably buy, or make, a wand.
Lyle
* This post was edited 09/04/21 07:15pm by an administrator/moderator *
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
Lynnmor
Red Lion
Posted: 09/02/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
Mine shot a powerful blast as well, especially when the blasted thing blew apart and hosed down the bathroom. I now use one that I made, the less Camco junk the better.
laknox
Arizona
Posted: 09/07/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Lyle
* This post was edited 09/07/21 02:23pm by an administrator/moderator *
