RV.Net Open Roads Forum: 2022 Tiffin - F-53 Chassis - Brakes
 > 2022 Tiffin - F-53 Chassis - Brakes
Horsedoc
Dixie --- N. Georgia
Posted: 08/31/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
RedRollingRoadblock wrote:
Horsedoc wrote:
The Ford Chassis Newmar we have now is the first after 2 diesel rigs. I thought exactly the same thing when we drove out of the dealer's lot in Knoxville. By the time we had gotten back home I was more used to the brakes and also said, "disc brakes would make me feel better". They still would!
We seldom get into the steep roads like we did with the diesels so I guess this will be the last MH we will ever own.
Keep safe and enjoy the road life
Hmm, Just how old is your F53? They have had 4-wheel disks for years.
It is a 2016 Canyon Star 3911 handicap equipped. Dealer said it was not disc brakes. I have not crawled under to see. Sure does not stop like discs
dodge guy
Bartlett IL
Posted: 08/31/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
It most certainly does have disc brakes all around. In 16 there was only Ford offering a class A chassis.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dougrainer
Carrolton, Texas
Posted: 08/31/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Since it is a 2022, Have you checked with Ford to make sure YOUR unit is not part of the Rear end recall? You need to. IF you are part, it was determined that Ford did not fill the Rear Differential with enough OIL and there is a nation wide Back order of NEW Rear ends that Ford is having to replace. AS of Friday, Tiffin had about 8 new built units on their lot that cannot be driven to the dealers because they must have the rear ends replaced. You are not allowed to drive the Motorhome as the rear end could fail at any time. Doug
RedRollingRoadblock
Oregon
Posted: 08/31/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't be the first time the dealer didn't know what they were talking about.
wildmanbaker
Kennewick, Washington
Posted: 08/31/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
If it has a Ford chassis, it has disk brakes. If it was driven any distance to the dealer, the brakes are broken in, and if it is fairly empty, the brakes should be touchy. Be carful doing a panic stop, you could end up with a seatbelt burn, it does stop the quickly, even with anti-lock brakes.
Wildmanbaker
Alex and Tee
Jacksonville , FL
Posted: 08/31/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
It was driven from Red Bay to Sanford, FL so it had 770 miles on it when I drove it off the lot. I’m sure if this chassis was part of the recall they wouldn’t have driven it but I will be sure to verify. The brakes are anything but touchy. I drove it empty and felt like I was trying to stop a train.
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
crawford
Dandridge Tenn.
Posted: 08/31/21 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Let me set you straight my buddys was part of recall and the drove it he got it with 800mile. then his son went under and check the rear
end it was low. he brought it back to dealer they say it wasn't . he said I want to see them checking it found them they check it from wrong hole.they filled it up to proper hole and order new parts. Check it your self make sure this is a fact.
Change from a c class to a A class Georgetown 07 triple slide
Alex and Tee
Jacksonville , FL
Posted: 08/31/21 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I just spoke with Ford Motor Home Customer Assistance and they ran my VIN and my unit is not included in the recall (PHEW!). We hit the road full timing 9/18 and are headed for Marathon Key (as long as there are no hurricanes headed that way). I need the maiden voyage to go smooth.
dodge guy
Bartlett IL
Posted: 08/31/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried stopping it like a panic stop? You really need to lay on the pedal.
mountainkowboy
Socal/NE Oregon
Posted: 09/01/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
We just picked up a 2007 F53 chassis moho. The brakes felt "different" from what I was used to, but they had no problems stopping it when called upon. I takes a fair amount of pedal to react, but after 1,100 miles towing 5,500 lbs, without the trailer it's a sports car......LOL.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
