RV.Net Open Roads Forum: Class A Motorhomes: Clicking sound when engine starting
 > Clicking sound when engine starting
ricelake922
Peterborough
Posted: 08/30/21 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hello
I have a 1996 Monaco Dynasty Class A RV.
When I start the RV I can hear a clicking sound prior to engine starting. Engine does not start up right away due to clicking sound. I am thinking the RV needs the starting solenoid to be replaced. Am I right? If so can someone please inform me where is the starting solenoid so I can locate it and replace it.
Thank you in advance.
rk911
DuPage County
Posted: 08/30/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
simple things first. i'd clean and tighten the starting battery terminals. the clicking noise could be a bad solonoid or it could be a dirty, corroded or loose connection.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
MountainAir05
New Mexico
Posted: 08/30/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Along with the connectors, The battery or the starter. Need to know if you have a Chevy or Ford chassis
RLS7201
Posted: 08/30/21 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I run into that problem on a friends DP coach. His problem was a loose connection on the starter solenoid. All the copper on the solenoid connection compresses over time and gets loose.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
ricelake922
Peterborough
Posted: 08/30/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you to all. The chassis is Roadmaster which was a Monaco thing. I will clean the battery posts on the starting battery. I would also like to clean the solenoid as suggested but it lease tell me where I can locate it. Thank you in advance.
Bruce Brown
Northern NY
Posted: 08/30/21 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Follow the battery cables, you'll find it.
And no, I'm not trying to be a smart aleck, just trying to make it simple.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
CA Traveler
The Western States
Posted: 08/30/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a diesel? If so the clicking and delay could be for the grid heater.
2014 Grand Cherokee Overland
Bob
NamMedevac 70
Reno
Posted: 08/30/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent suggestion. I just recently had this same problem on a Dodge Ram 1500 and the battery cable connections at the bat terminal were rotten. Battery and Alternator were working just fine. Sometimes they are just loose even if you think they are tight so double check again.
John Wayne
Long Beach, Ca
Posted: 09/01/21 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Take a set of jumper cables hook the neg post on the battery to the frame to ground it and try starting it if the clicking go away you have a ground problem. Fought this problem on friends MH in St George Utah in July in 105 temps. Turned out to be a bad ground cable.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
bigred1cav
ohio
Posted: 09/02/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
fuel pump
