RV.Net Open Roads Forum: Towing: Need help - Weight distribution hitch installation pics
Search only in Towing
Open Roads Forum  >  Towing
 > Need help - Weight distribution hitch installation pics
Page of 7
Posted: 09/07/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
bobby7718 wrote:
Haven't yet - wanted to rule out the VT first.
Yes, the mechanic said the exactly same thing - he couldn't believe the struts could go bad on 37k mileage.
But he found both of fronts are bad with leakage, see attached pictures.
While not impossible (front struts were junk on my 2016 Chevy at about 60k miles), you should absolutely be able to feel if the struts are blown. It'll bounce like an old Buick over every speed bump.
The shafts of the shocks (struts) in your pic have a cover over them, thus any leaking oil from the seal would be on the inside, not the outside. And the one pic appears like the back side of the spring is clean. I believe that's some road debris/oil/undercoating, not leaky shock oil. Plus it looks like the shock covers aren't coated in it.
To each their own, but I'd go hit a couple speed bumps and see if they're shot or not. Although new Bilstein's will likely be stiffer and handle a bit better, I still maintain that there is NO problem with your truck.
2017 Heartland Torque T29
Posted: 09/07/21 10:49am Link  |  Quote  |  Print  |  Notify Moderator
bobby7718 wrote:
Not sure about the history, probably got a lot of towing for that 35K miles.
Does the inside of the hitch and the safety chain loops look like it had alot of towing?
Doesn't actually matter, but that would be tangible evidence, beyond it being ordered with a towing package.
Back to the trailer, someone else mentioned it, but how much experience do you have towing?
If you're new to towing, its possible that your comfort level or perception of how it "should" tow is not yet fully developed, so to speak.
* This post was edited 09/07/21 11:02am by Grit dog *
bobby7718
New England
Posted: 09/17/21 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am actually very new to towing. Had a few rental experience of class-c . That's about it prior to towing a TT.
Finally got the all front struts(bilstein 6112) and rear shock(bilstein 5100) replaced yesterday. The garage who did the installation doesn't do alignment, have alignment scheduled next Monday.
Gave a test drive, sadly, didn't change much, especially on the highway. (knowing I needed to do a bit adjustments since all measurements could change with the suspension replacement - but wanted to give it a try).
Ordered Equal-i-zer 4 point with sway control, as the last resort.
Posted: 09/18/21 06:16am Link  |  Quote  |  Print  |  Notify Moderator
If the trailer is really tail wagging on its own, without any input to cause it or wind or bad roads or …..then it’s usually 1 of a few conditions.
1. Trailer just grossly too heavy for the truck. Not the case here
2. Trailer tires too soft/ under inflated.
3. Insufficient tongue weight. Believe you posted healthy tongue weight though.
4. A lot of weight far aft of the axles. Either by ( bad ) design or some very heavy stuff in the back of the camper.
Just suggestions.
BenK
SF BayArea
Posted: 09/18/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Suggest one more thing before tossing more money at the situation…
Drop your WD Hitch head one bolt hole down on the shank…as long as there is ground clearance, which from your pictures, says there is
Then reset up everything as before and the goal is to have the trailer slightly pointing down from level.
That I has been the biggest help in solving others who have asked
Second is to transfer more weight off of the TV’s rear axle and over to the TV’s front axle. Not a ton of weight, just a bit more.
Good luck!
-Ben Picture of my rig
bobby7718
New England
Posted: 09/25/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Finally some updates.
Today I installed the newly arrived equalizer WDH(Equal-i-zer 4-point Sway Control Hitch 1000LB). Driving on highway seems a bit better, but still not reach the comfortable towing experience. Can still feel a bit sway(especially when been passed, or sudden cross-wind), I had to concentrate on steering wheel when that happened. Also went to the CAT scale to get some numbers.
I recall it was mentioned that the adjustments of the WDH(even equalizer one) also takes a few tries. In my first attempt, hitch head was on a higher side( coupler 23 1/8, head was 24), which caused a raise in the middle. (Also that measurement seems suggest over-adjust - front well was even lower after WD engaged).
In the second attempt, I lower the head 1 bolt hole (also recalled BenK's suggestion above), removed one spacer washer, which made the head up/away from the TT a bit.
Below are the results of my second attempt.
Any further suggestions will be highly appreciated. Thank you
Calculation was following this instruction. https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25928885/gotomsg/25929827.cfm#25929827
BenK
SF BayArea
Posted: 09/25/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
You are getting close, and suggest lowering the hitch head one more hole. As from the picture...it is pointing up a bit. Tongue pointing should be level at it's highest pointing and prefer pointing slightly down
As for washers, they tilt the head backwards, towards the trailer, and that makes the trunnion bars point lower. That in turn provides more 'potential' tension you can impart on the trunnions...meaning more weight can be transferred to the TV's front axle...which at this time don't think you need to do
bobby7718
New England
Posted: 09/25/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you Benk for the suggestions, will give it a try.
Posted: 09/25/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
You can feel a “bit of sway” when catching a crosswind or passing a semi?
Dude, that’s normal and no wdh is going to make the big sail your towing disappear.
Maybe get someone else who knows towing to test drive your rig. Like a second opinion. I believe what your experiencing is normal.
parker.rowe
Delaware
Posted: 09/25/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
There is no adjustment you can do to get rid of the push from getting passed or getting hit by a crosswind.
From my experience, the bigger the speed difference between you and the person passing you, the more you will feel it.
A push is not the same a sway. I think a lot of people get it confused. I'm not sure how to describe it but real sway but its no fun. I'm sure someone here has a great description.
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
Page of 7
