RV.Net Open Roads Forum: tow limit - 1984 Ford Honey with 460 motor under hood
 > tow limit - 1984 Ford Honey with 460 motor under hood
sputterbug10
illinois
Posted: 08/31/21 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Do you all think this camper could pull a car that weighs 3700 lbs?(1984 Ford Honey - 460 motor)
enblethen
Moses Lake, WA
Posted: 08/31/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
It should do just mine!
It has three speed automatic which will make it a gas hog along with 460!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RetiredRealtorRick
Gulf Shores, AL
Posted: 08/31/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
It certainly will, and will probably affect your gas mileage by only about 1 mpg.
Instead of 5 mpg, you'll get about 4! 460's LOVE the gas!!
. . . never confuse education with intelligence
Posted: 08/31/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Not to sound sarcastic, but there are so many variables, not the least of which being it's an almost 40 year old rig, with no supporting information provided, that it's virtually impossible to answer.
Furthermore, if you're needing to ask that question, your knowledge of vehicles and towing, in general, is not conducive to successful road trips in an old vehicle that will be working at high duty cycle.
Theoretically, a little moho like that with a big block and a C6 (even an anemic 80's model) has enough juice to pull a toad, no problem, but again, there is so much more to your question, you, yourself need to analyze whether the moho is mechanically safe and competent to tow and stop the extra weight and almost as importantly, consider where and when you're towing.
IE, cool weather, in Illinois is far easier on the tow vehicle than say 100degrees in the middle of summer or pulling a 6% grade at high altitude.
Good luck with your venture!
2017 Heartland Torque T29
2 many 2
Posted: 08/31/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I had that same RV for ten years, the truck frame stops just behind the rear axle. The RV manufacturer welds / adds a channel to extend the back part of the Motorhome frame.
Often this channel extension is considerably smaller than the OEM truck frame and the receiver / hitch is attached to that. You will want to have a welding shop inspect the hitch for overall capacity evaluation and possibly beef it up with some extra welded brackets or replace it all together with a higher rated hitch.
You will experience 4 to 5 mpg @60 mph that's about 28 ounces of gas a minute! [emoticon]
Monterey, California
Posted: 08/31/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it will do fine. Brakes may be necessary however.
theoldwizard1
SE MI
Posted: 08/31/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
37 year old chassis ? It needs a professional to inspect the suspension, steering and brakes !
enblethen
Moses Lake, WA
Posted: 08/31/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Whether the frame was extended would be determined by the length of the MH. Some do not have frames extended where long ones do. You can look at the frame to determine if has been. Frames on some rigs are extended using a butt weld where others are plated at the joint adding strength.
