RV.Net Open Roads Forum: Truck Campers: Thoughts on Lance Nose Cap Filon Replacement
 > Thoughts on Lance Nose Cap Filon Replacement
MLD
Colorado
Posted: 08/31/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
The nose cap filon on my 2006 Lance 951 started delaminating a year or two ago, some of it may have been due to bad caulking on a marker light but some is separate from it and I think it's just a result of old glue and heat from sitting in the sun for 17 years, but it has progressively gotten worse and is very unsightly. I've removed some of the trim to inspect it and while the sidewalls are laminated to plywood the nose has a hardboard/fiberboard backing that is less than an 1/8" thick and appears to be curfed on the back in the areas where it bends around the curves of the nose. I would need to remove both the filon and backing to do the job right, I can buy some filon and 3M 1357 and have plenty of experience laminating but have no idea where to get such a backing. The rest of the camper is in perfect condition, other than the faded & cracked decals, so I would like to keep using it and fix the nose, so I'm looking for thoughts on how to fix it with filon or maybe something other material. I wished it was as simple as replacing the old aluminum siding. Thanks for any ideas.
jimh425
Western MT
Posted: 08/31/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Have you thought about a Lance molded front cap instead of filon? I don’t know if it is possible to buy one from them and install yourself, but if not, it seems like you could build your own out of fiberglass or have it done.
There are a few different threads on working with filon here, but you might have to search the archives or do an internet search with site”colon”rv.net in search string to find them.
Kayteg1
California > Nevada
Posted: 08/31/21 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check Lance forum? They have several rebuild pictorials available.
Applying new filon require some jigs to apply even pressure, what is not easy for DIY.
I repaired nose on my camper by pulling the siding out, replacing rotten wood, adding Styrofoam where fiberglass was used and gluing it back.
It did not make it perfect cosmetically, but better frame that original.
MLD
Colorado
Posted: 08/31/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
That would be great to just attach one of those caps, don't think I haven't thought about it, but I figured Lance probably wouldn't sell one and I doubt it would fit anyway. I have no idea how to build one or where to have one built, probably not a lot of people out there making things like that.
MLD
Colorado
Posted: 08/31/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'll check it out. I think I could do it, my immediate problem is the backing for the filon. I thought about curfing the back of some 1/8" masonite but that sounds difficult.
Kayteg1
California > Nevada
Posted: 08/31/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
On front big curve the filon has no backing. Just 4 or 5 ribs.
phillyg
SWFL
Posted: 09/01/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Use 1/8" luan plywood, kerfing on the backside as needed.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Posted: 09/01/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
In lieu of filon, I’ve considered light gauge diamond plate sheeting.
Fairly inexpensive and would look good I think.
2017 Heartland Torque T29
MLD
Colorado
Posted: 09/01/21 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I will look for some, that would be a better option than the hardboard.
I thought I was spelling kerf wrong but didn't bother to look up the right way. Thanks.
Bedlam
PNW
Posted: 09/01/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
My 2012 Arctic Fox came with this on the leading and trailing curves as an option.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
