RV.Net Open Roads Forum: Tech Issues: Propane Tank level question
 > Propane Tank level question
Nevrdun
Smethport, PA
Posted: 08/31/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
My tank level indicator seems to be showing red even though I know both tanks are full or near full. Please see photo. Can anyone tell me what my issue may be? Thank you for any input you may provide.
[image]Click For Full-Size Image.
May I become the person my dog thinks I am
MarkTwain
Northern, Ca. , USA
Posted: 08/31/21 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Buy 2 new regulators. Buy regulators with easy to read RED/Green window indicators.
Nevrdun
Smethport, PA
Posted: 08/31/21 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you. Can you suggest where I would get the regulators?
enblethen
Moses Lake, WA
Posted: 08/31/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it is not over filled? Turn tank off, take line loose and see what direction needle goes. The valves need to be turned on verrry slowly otherwise tank thinks there is a leak.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MarkTwain
Northern, Ca. , USA
Posted: 08/31/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Find a good RV shop in your area. You can also just go to Amazon and order them. Just don't go to Camping World for parts or repair.
LadyRVer
Posted: 08/31/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Are tanks turned off?
dougrainer
Carrolton, Texas
Posted: 09/01/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
1. Those are HORIZONTAL tanks.
2. The level gauge is a FLOAT designed Gauge
3. Makes NO difference if tank on or off.
4. REGULATOR REPLACEMENT???????????????????????????????? WHY
5. Yes, if OVERFULL the gauge may do that
6. If tank upside down it will do that Rotate 180 degrees and see what happens
7. Sometimes a float can get "stuck" inside the cylinder. Remove the cylinders MAKE SURE they are really full. Then lay down or rotate 360 degrees a few times to free up stuck float.
8. This is the BEST and ONLY type level gauge system that always works, as it uses a inside float to gauge fluid level. It is the same design used on ASME motorhome tanks. Doug
dougrainer
Carrolton, Texas
delete dual post
Birdnst
Poquoson
Posted: 09/01/21 11:49am Link  |  Quote  |  Print  |  Notify Moderator
There is normally a black cap that goes over the top of that dome.
If it was there then you would only see the green at the bottom, then when the tank you are running from goes empty the red would drop down into view.
You are missing a piece, go to your local rv parts store and look at new regulators.
If you cannot take good care of what you have, you will not have anything good for very long!!!
valhalla360
No paticular place.
Posted: 09/01/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Which indicator are you talking about?
- The gauge on the tank
- The pop up button on the regulator
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
