RV.Net Open Roads Forum: Are Ground Bonding Plugs required for Each Inverter/Genny?
 > Are Ground Bonding Plugs required for Each Inverter/Genny?
Baja Man
Inland Empire, CA
Posted: 08/31/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am installing a new Progressive Industries hard wired EMS (EMS-HW30C).
I want to use a ground-neutral bonding plug on inverters/gennys to avoid using my by-pass function.
I plan on using my two Champion 2500W Dual Fuel inverters combined, using the Champion 30AMP ParaLINK Parallel kit.
Will each inverter/genny need its own plug or will one plug on one them suffice?
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
BFL13
Victoria, BC
Posted: 08/31/21 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.championpowerequipment.com/product/100740-30-amp-parallel-kit/
Not understood--you can only plug into one of the receptacles at a time with the plug that has the EMS on it.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
Posted: 08/31/21 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Just one assuming all grounds are connected.
675w Solar pictures back up
BFL13
Victoria, BC
Posted: 08/31/21 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
OP is asking about plugging into gens, but the two receptacles are in the paraLink.
ktmrfs
Portland, Oregon
Posted: 08/31/21 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
if it is like the honda, nope, only 1 plug needed. the parallel operation truely parallels the 120V outputs.
2011 Keystone Outback 295RE
Baja Man
Inland Empire, CA
Posted: 08/31/21 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
The neutral-grounding plugs I am referring to are plugged into the inverters 120V receptacle
BFL13
Victoria, BC
Posted: 08/31/21 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have seen the bonded 15a adapters used for that and you would have one on the shore power cord plug. You say you will be using the parallel kit, so you will be plugging into one of the two 30a paraLink receptacles depending on your plug type, not into one of the gens.
Do you intend to have a 30a adapter modified to be bonded? Very confusing.
bob213
Fresno, CA
Posted: 08/31/21 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
When I parallel my Hondas it only takes 1 (one) bonding plug. Either generator and your EMS will see a common ground.
wnjj
Cornelius, Oregon
Posted: 08/31/21 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
He’s planning to plug the RV into the paraLink kit but the bonding plug into one of the 120V receptacles on one of the generators.
The answer is it will work fine so long as the ground wire (I.e. the screw loop terminal) from the paraLink is connected to the ground lug on the generator with the bonding plug.
All bonding does is connect the green ground wire to the neutral. Once all neutrals are connected to each other and all grounds are connected to each other bonding can be done on either generator or at the unused the paraLink receptacle.
Posted: 09/01/21 04:53am Link  |  Quote  |  Print  |  Notify Moderator
As I understand it the parallel link has only two wires to each generator. Thus you will need to bond at the 30 amp outlet in the P-link. Easiest way (if said assembly is not molded) is to open the outlet assembly and add a jumper.. Just make sure you jumper the PROPER (Neutral/Ground) pins.
Actually with inverter generators the Surge Guard is not needed so you an use the bypass mode safely.
But there is still a good reason to bond.
