RV.Net Open Roads Forum: Help for Unreliable combo brake turn signal light on trailer
 > Help for Unreliable combo brake turn signal light on trailer
vsssurplus
PA
Posted: 09/01/21 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Ghost in the machine! I have this really annoying issue with one of my brake lights/turn signals. It is on sometimes and off others. If it's off, I can tap the back of it with a screwdriver a few times and it starts working again. It's driving me crazy. I'm not even sure how to remove it. I don't see any screws on either the inside or outside of the trailer. It's oval and set in a rubber gasket.
Any advise would be welcome.
craig7h
Branson MO area
Posted: 09/01/21 04:01am Link  |  Quote  |  Print  |  Notify Moderator
When I had a 5th wheel, I had rear light issues that drove me nuts. It seemed the problem was related to the ground wire. I ended up removing the light can and soldering all the wire connections. I also tighted up the light bulb connection. If you are using the 1157 bulb its just sitting in the correct spot by a hope and a prayer. You may have to rework that area also.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
burningman
Seattle, WA USA
Posted: 09/01/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Most lights set in a rubber gasket are simply held in by that gasket. You just pry it out.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Gdetrailer
PA
Posted: 09/01/21 07:21am Link  |  Quote  |  Print  |  Notify Moderator
If it looks like the one in the pix below, they are a friction fit, no screws hold them in.
To remove, you take a flat blade screw driver, insert the blade between the light and gasket. Then pry the light out of the gasket.
This type of light is typically sealed and the lamps inside are not replaceable. In this case, you replace with a new oval module.
You might also be presented with a plug in on your existing light, that plug may be loose or corroded which can cause intermittent light operation. Push plug back on and or check and clean and corrosion you might find and retry the light.
If no plug in, then issue most likely is inside the module and replacing the module is the fix.
To reinstall, make sure gasket is installed and seated, then install one end into gasket opening then push and wiggle the remaining portion of module until it is firmly seated in the gasket.
dougrainer
Carrolton, Texas
Posted: 09/01/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
IF it is a LED light assbly, odds are it is BAD. BUT, you need to pop it out and check the wire connections to the light. IF they used a Tap Splice, the splice is probably not installed correctly. Doug
This is what a tap splice looks like.
https://www.lowes.com/pd/Utilitech-20-Co........snohk6LJQMFG3xoC8HoQAvD_BwE&gclsrc=aw.ds
BB_TX
McKinney, Texas
Posted: 09/01/21 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
If they are the dual element incandescent bulbs, I have had problems with them on utility trailers a number of times. And almost always with the thin copper strips making good contact to the bulb contacts. Tapping on the assembly would cause them to work. For a while. Always eventually had to remove the lens and bulb and slightly bend the copper strips ti make tighter contact.
burningman
Seattle, WA USA
Posted: 09/02/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
By the way, if they aren’t LEDs, replace them with LEDs. They’re brighter for a reason many people don’t consider: even if an incandescent bulb was as bright, by the time it’s 12V power goes through a bunch of small-gauge wire and a connector or two, it’s getting pretty weak power.
The LED doesn’t need much power and still shines at full brightness.
That’s also why you still want to own an incandescent 12V test light for troubleshooting.
LED test lights will glow on the faintest current, sometimes misleading you to believe a circuit is good when it isn’t.
vsssurplus
PA
Posted: 09/04/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses! I simply replaced both fixtures with cheap LEDs from Amazon. All seems to be working properly now [emoticon]
