RV.Net Open Roads Forum: Tech Issues: Jacked your to house batteries
 > Jacked your to house batteries
Gdetrailer
PA
Posted: 09/01/21 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
rlw999 wrote:
They have a 2000W/2000Wh device for $2000 -- that's 160Ah@12V, so that's not insanely expensive when 200Ah of BattleBorn Lithium batteries cost $1800 (and that's just for the batteries, no charger, no inverter, etc that you get with the Jackery).
Losing 15% to power conversion losses is not terrible a $500 AIMS 2000W inverter has 10% loss at full power.
It's definitely not a generator, but it's not useless waste of money either if you want a decent amount of portable power that you can carry around with you.
Losing 15% (inverter loss)to get to 120V and then an additional 15% (Converter loss) to run 12V devices is 30% loss.
In your example of 160 Ahr at 12V that is a 48Ahr capacity loss giving you only 120 Ahr to use.
Makes using a BattleBorn battery direct a much better choice.
rlw999
Washington State
Posted: 09/01/21 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Man, times sure have changed when you can say "only 120Ah" when referring to RV batteries!
My RV still uses flooded lead acid batteries since I don't boondock enough to make it worth replacing them. And those 2 batteries combined only give me around 100Ah of usable capacity. Like I said in an earlier post, I have a unit similar to his Jackery and I use it to power a few things to help preserve battery life on the house batteries -- and I use that power pack for much more than RV'ing, and putting Lithium batteries in the RV won't help with those use cases.
He already owns the Jackery, so that's sunk cost, so he may as well use it even if he loses 30% due to conversion losses. 30% of $0 is still $0.
Posted: 09/01/21 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Just be aware that when you go from battery to Inverter you will lose at least 10% of the power. Going back to battery another 10%. OR MORE IN BOTH CASES.
CA Traveler
The Western States
Posted: 09/01/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
The Jackery 1500 battery is 60.9Ah at 25.2V, so equivalent to about 120Ah for a 12V battery, better than many car batteries.
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Posted: 09/01/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
rlw999
The power factor on my PD converter is 0.7. The OP doesn't state the type of batteries he has--but if they are lead acid, that may cost another 10% loss.
Taking your figure of 15% loss on the Jackery and then the PD after that, makes it possible but extremely wasteful. My PD is only 30 amps and draws 750 watts. You might get 2 hours of charging out of the Jackery (but I doubt that.
I'm not a fan of LI batteries--but there are more than a few that are considerably cheaper than the Battleborn brand.
So sure, the OP can use it--but he would be far better off using it as a power supply for low draw devices.
If you are in a tent, a Jackery might be useful when tentdocking (boondocking in a tent).
Regards, Don
ReneeG
Meridian, Idaho
Posted: 09/02/21 07:03am Link  |  Quote  |  Print  |  Notify Moderator
What about compatibility of the Jackery with the inverter? We were looking into getting lithium batteries for our FW, but we had to check on our model of inverter and if lithiums would be compatible.
BTW, we have a Jackery as backup for hubby's CPAP to use while camping. We did a test run with the CPAP which was a no brainer, but we also did a test run of it to power our Dometic portable fridge/freezer and it ran for an entire week. We've got solar panels to recharge the Jackery while out dry camping.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
CA Traveler
The Western States
Posted: 09/02/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
FYI The Jackery with it's inverter output is 120V AC so compatibility is not a issue. If it has a DC output then it's inverter is not involved.
Lithium batteries are very different from flooded batteries and a compatibility charger is needed. If you have a charger/inverter it's the charger part that charges batteries.
CavemanCharlie
Storden,MN
Posted: 09/02/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
countrykids wrote:
When boondocking, can I plug the RV into a Jackery unit to transfer amps into the house batteries? I know I loose some power going from 12 v to 110 and back but I am looking for an easy way way to make those available to the whole RV.
Thanks.
If you already own it then why not give it a try ?
I once had a small TT with only one battery and no easy way to install a second one. I had one of those portable "Jumper Packs" that you use to jump your car in a emergency. When my TT battery would start to run down I would hook up the Jumper Pack to give it a little more juice. Everyone told me it wouldn't work, and maybe it didn't work well, but it would allow me to go dry camping for one more day.
You'll never know unless you try.
(On the other hand if you don't already own it then that is a entirely different matter.)
