RV.Net Open Roads Forum: Tech Issues: Gas regulator issue, or Fridge?
 > Gas regulator issue, or Fridge?
rdhetrick
Posted: 09/02/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Turn off the DC, light the stove, does the sound come back?
Rob
2006 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
dougrainer
Carrolton, Texas
Posted: 09/02/21 07:29am Link  |  Quote  |  Print  |  Notify Moderator
May or may NOT. The refer uses very little LP while the Stove uses a lot. Doug
Byrogie
Whisper Valley Alberta
Posted: 09/02/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
OP here
Further info: Noise comes from either compartment, whichever is in service.
Main regulator replaced previously, no change.
Will turn off fridge and check stove this weekend if it happens, it is random both in frequency and intensity.
And yes, the sound stopped immediately after fridge was turned off.
enblethen
Moses Lake, WA
Posted: 09/02/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Which compartment?
Do you have an inverter and is it in same compartment?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Vintage465
Prunedale CA.
Posted: 09/02/21 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt if it's your fridge. Generally speaking the more use/flow thru a reg. will cause more singing(whine). I would think that your should be able to duplicate the sound using an alternate source of flow as rdhetrick mentioned. Though I've not noticed my reg singing, I do know factually that all natural gas regs sing under use. I may not hear mine 'cause I'm somewhat hearing impair.......well, my wife thinks so anyhow. You can have your pressure checked, or check it yourself for lock-up(no flow) and for flow. Should be real close to 11" water column when flowing. Or you can change it and see/listen if the new one sings to ya.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
Bird Freak
Dallas Ga.
Posted: 09/03/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Mine did the same thing. Replaced propane regulator. problem solved.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Byrogie
Posted: 09/08/21 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Update from this past weekend:
Heard a low whine second day in. Shut off fridge, stopped. Lit stove, whine came back. So looks like regulator? That would be 2 bad ones in a row, including original as we bought trailer new.
