RV.Net Open Roads Forum: Travel Trailers: Air Shocks or Air Bags on TT
 > Air Shocks or Air Bags on TT
spoon059
Just north of D.C.
Posted: 09/03/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Rbertalotto wrote:
but I don't see them helping with side to side leveling like you initially asked.
Really, Having the ability to raise one side or the other with a device between the chassis and the axles is difficult to comprehend? It's EXACTLY the same thing as driving up on some boards to level the RV side to side.....
I understand the basic idea, its not a reading comprehension issue. But how much lift articulation are you really going to get and how much trouble is that worth, as opposed to putting out boards or an Anderson leveler?
2015 Ram CTD
2015 Jayco 29QBS
Rbertalotto
Massachusetts
Posted: 09/03/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
I have the the red plastic, under wheel, wedge type levelers....a great solution, but a pain when they are covered with mud and need to be deployed and undeployed and stored etc...Plus where I usually camp, I need to also bring a couple plywood boards so they don't sink into the ground. And a few trips in and out of the truck to check level if I'm alone.
They give me about 3.5" of lift. I placed a bottle jack between the frame and the spring perch on my trailer and I can get just about the sale lift with this method.
Nothing to touch, nothing to store, nothing on the ground.....
And I realized I really only need one axle to be manipulated....You don't have to do both. But stability improves if you do both.
Now, If there was a way for the lift mechanism to push against the top of the tires, rather than the axle, this would REALLY stabilize the trailer from rocking, just like those devices you install between the two wheels!
RoyB
Dartmouth, MA
2018 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
420w Solar / Bogart SC2030 / Trimetrics
Rbertalotto
Massachusetts
Posted: 09/03/21 06:41am Link  |  Quote  |  Print  |  Notify Moderator
BTW, have you checked the TW since you lifted the trailer? Or did you lift the ball as much?
I reconfigured the entire hitch dynamics once I raised the trailer. Had to raise the ball nearly 5" and readjusted the load equalizing bars so there is nearly no sag in the back of the truck. The truck is a RAM 2500 with 3300# payload capacity.
JRscooby
Indepmo
Posted: 09/03/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
For storage, a cloth bag, with trash bag for liner will control the mud spreading to the rest of stuff.
Most ramps have a larger footprint that the tire that sets on it. So if you have issues with ramp sinking, the tire will too.
If you are moving the trailer up a ramp to level, mount a vial, or ball in curved tube where you can see it in mirror.
If building a ramp, then putting tire on top, mark your level so you can tell from jump how tall the ramp must be. (A 2 foot long whiskey stick on the floor, lift the end to center bubble. Measure end to floor. Each half inch will call for a 2X on the stack.) I build the stack next to tire, put chock behind tire on high-side. Pull up, slide stack sideways behind tire, then back up to chock.
Not sure, would you need longer stroke to get same lift out of 1 axle?
Just trumping here now; Mount a pin to the frame so it sticks out centered between tires. Eye on top of jack, (thinking of something like a bottle shaped screw jack that came with light-duty Ford trucks from at least mid '60s to mid'80s) Then make a wedged shaped heavy duty pan that fit between tires, below jack when hanging on pin. Tighten jack would lock and lift.
Rbertalotto
Massachusetts
Posted: 09/03/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Interesting idea! Thanks...
goducks10
There
Posted: 09/03/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
This
https://logicbluetech.com/
With these
https://www.beech-lane.com/camper-levelers
I can sit in my truck with the app and backup until the LMP shows level.
Makes it easy for one person.
goducks10
There
Posted: 09/03/21 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Dbl post
Gdetrailer
PA
Posted: 09/04/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
They do make stick on graduated levels that readout in inches.
Found HERE for under $12 for two..
They also make graduated round bubble levels.
Inch reading will take the guessing out of your setup at a much lower cost than rigging air shocks and may be more reliable.
No sense adding extra things to break, RVs break easy enough..
afidel
Cleveland
Posted: 09/04/21 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
spoon059 wrote:
Rbertalotto wrote:
Thoughts?
Waste of money. Get yourself some Anderson levelers (or Beech, which are cheaper) and balance your tires. MUCH cheaper and will give you a smoother ride in the camper and legit leveling.
Maybe I'm just unlucky but in the first 7 months of owning my new trailer I've been on sites that exceeded the height of my Andersons 3x. I end up building platforms out of 2 stacks of 3x Lego bricks with another 2x as caps. I use the Andersons as ramps to get up onto and off these towers.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
spoon059
Just north of D.C.
Posted: 09/05/21 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Situations like that I would either try to reposition my camper to be more neutral before leveling, or I would use my shovel to lower the high spot. I wouldn't want one side of my camper to be more than 4" higher than the other. Then you start having issues with the steps, access to outdoor kitchen, instability when stabilizing, etc.
If you have exceeded the height of your Anderson's (4") by 3 times, thats a foot off level over 8 feet wide. Are you camping on the side of a mountain?
