RV.Net Open Roads Forum: Travel Trailers: Electric brakes issue
 > Electric brakes issue
plasticmaster
Home
Posted: 09/01/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
When I plugged the power cable from my camper to my truck yesterday, I got a message on my dash that said check trailer wiring. I tested the brakes and indeed they were not working. I blew out both ends of the plug really well with my air compressor, plugged it back in, and then everything worked fine. We did have a little rain earlier in the day. This has happened a few times now. Is there anything more permanent I can do to ensure a good connection so I don't have to rely on the air compressor? Thanks.
Boon Docker
Posted: 09/01/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
This cleaner or something similar.
JRscooby
Indepmo
Posted: 09/01/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Cleaner is good, then put Di-Electric grease on the plug, so it covers the connection
MitchF150
Puyallup, WA
Posted: 09/01/21 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Get a small flat blade screw driver and on the trailer plug side, carefully pry the blades open a bit more so they will have a tighter fit on the trucks plug.
Good luck! Mitch
2 many 2
Posted: 09/02/21 02:30am Link  |  Quote  |  Print  |  Notify Moderator
X2
WNYBob
Tonawanda, NY
Posted: 09/02/21 06:46am Link  |  Quote  |  Print  |  Notify Moderator
I see this often here on RV.net, but Dielectric grease is used for sealing, protecting and electrical insulating. Improves electrical performance by reducing arcing, voltage drop and other conditions. This will help keep out water and other contaminates.
But it does not clean or lubricate your plugs, the cleaner mentioned earlier is what should be used first to make better contact.
Lynnmor
Red Lion
Posted: 09/02/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Keep your trailer plug in a Plug-Guard when not in use. Plug in and out several times when hooking up to wipe the contacts. Using the spray mentioned above is worthwhile.
Monterey, California
Posted: 09/02/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Plugs "wear out." I replaced mine and no further issues.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ktmrfs
Portland, Oregon
Posted: 09/02/21 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
2 many 2 wrote:
X2
X3, detox is good stuff.
2011 Keystone Outback 295RE
Gdetrailer
PA
Posted: 09/02/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, when not in use or towing just tuck the connector back under the propane tanks on the tongue making sure the cable has a little droop and the plug is above that droop.
The propane tanks create a natural shelter from the rain and the droop in the wire creates a drip loop that stops water from following the wire to the connector end.
No greases, no air compressor, cleaners ever needed if you simply shelter the plug.
You still do need to periodically check and clean any corrosion on the connector since they are typically brass and brass naturally oxidizes from moisture in the air (the oxidation creates a nonconductive layer on the surface). For oxidization, I fold some sand paper a few times then insert it into the connector to shine up the brass.
