RV.Net Open Roads Forum: Wanted - Fresh Water Hose for "Olds"
 > Wanted - Fresh Water Hose for "Olds"
dcmac214
SW OKLA
Posted: 09/02/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Looking for fresh water hose with feature for couple getting on in years and going down in strength.
Want water hose, don't care what color, that has a "grip" on both ends. "Grip" being an easy-to-grasp assistant for tightening the connections. There are lots available with a "grip" on the female end but haven't been able to find one with "grip" on both ends. Closest I've seen so far (not bought) is one with hex ends for a wrench but that's not what I want.
enblethen
Moses Lake, WA
Posted: 09/02/21 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I found using good quality disconnects work better. Install connectors with wrench once.
Edit: I use brass quick connects.
* This post was edited 09/02/21 12:20pm by enblethen *
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
agesilaus
North Florida
Posted: 09/02/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
We like the Flexilla and get some quick connects. Then the only fitting you have to deal with is the one to the campground faucet.
Hose
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Boon Docker
Posted: 09/02/21 10:22am Link  |  Quote  |  Print  |  Notify Moderator
This one looks pretty good.
Posted: 09/02/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Was going to suggest quick couplers.
2017 Heartland Torque T29
IAMICHABOD
Sunny So Cal
Posted: 09/02/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I am with Grit Dog on this one. Being an "old" with one pretty much useless left hand I have equipped all my hoses and other parts with Quick Connectors
The only thing I have to connect that requires screwing to the hose bib is my Pressure Regulator which has a large grip on the end,everything from there on has quick connects,pressure regulator,water filter,then hose to RV all equipped with quick connects at both ends.
Former El Monte RV Rental
Buying A Rental Class C
mlpeloquin
San Jose, CA
Posted: 09/02/21 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I use Greenleaf garden hose couplers. They do not leak and used several years now. Tractor supply has the best prices.
Greenleaf - Tractor Supply
Janss
Sedona, AZ
Posted: 09/02/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a brass elbow on my motorhome city water intake connection. Like this brass elbow.
Then I just hold the hose still with one hand and turn the brass elbow end with the grips to tighten onto the hose. Works great for me. I have used quick connects in the past, but I actually find that disconnecting is a little hard for me.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
RetiredRealtorRick
St. Augustine Beach, FL
Posted: 09/02/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
We own one of these. Best hose we've ever owned, and definitely not overpriced. We bought ours through Home Depot. At the time they had the best price and free shipping as well.
OOPS!!! Attached it to the wrong post. We have the FLEXILLA hose
. . . never confuse education with intelligence
Bumpyroad
Virginia
Posted: 09/02/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
the best easiest solution.
bumpy
