RV.Net Open Roads Forum: Travel Trailers: TT with its own motors!
 > TT with its own motors!
Rbertalotto
Massachusetts
Posted: 09/02/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
How about a TT with two electric motors to help with the towing? And at the campsite, it can unhitch and back itself into the camping spot! Designed to be used with electric vehicles, but has applications for petro powered vehicles too....
https://www.greencarreports.com/news/1133124_towing-with-an-ev-are-electric-trailers-the-future
RoyB
Dartmouth, MA
2018 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
420w Solar / Bogart SC2030 / Trimetrics
Monterey, California
Posted: 09/02/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I would be concerned with the weight of the batteries and electric motors. Wouldn't be like a train with engines in the rear.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
valhalla360
No paticular place.
Posted: 09/02/21 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
The problem with electric vehicles is installing motors big enough to pull a trailer but supplying that power to those motors (F150 Lightning has 560hp)
While it's possible to design a powered trailer axle, it's complicated and expensive (and their example was a tiny 1500-2000lb trailer (at least before the battery pack got added).
A simpler and far cheaper solution would simply be to add a large battery pack in the trailer with a quick connect that could feed the trailer battery power to the tow vehicle to give extended range.
Assuming you can stop a short distance away from the campsite, you then have a battery pack capable of powering the rig for a couple days (not conservation mode but crank up the air/con and be comfortable support).
Say you have an F-150 Lightning with 150kwh battery pack and 300 mile range.
- Add a 25ft trailer and you are probably down to 150mile range towing.
- If the trailer had 75kwh, you could up the range to 225 miles.
Swing by a fast charger (assuming you can fit in) just before arriving at the campground and you may start the weekend with 70kwh.
- With air/con and other misc loads, you may be drawing an average of 1.5kw, so 70kwh will last you around 46hours.
- Swing by the fast charger on the way out to top up and you have 225 mile towing range on the way back.
Still going to be a hassle compared to just filling the gas tank and it's going to add probably $10k to the cost of the trailer (including beefing up the suspension) but some of that will be balanced against buying and maintaining a generator. Net will cost more but not insurmountable for trailers at the upper end of what 1/2 ton trucks can pull.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rlw999
Washington State
Posted: 09/02/21 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting concept, but I wonder if it's worth all the complexity and expense of putting powerful drive motors in the trailer rather than just putting batteries there and some kind of charge cable that allows charging while driving?
Being able to motor the trailer around the campsite sounds like a nice feature, but it better have some good safety lockouts, would not be fun to have the trailer accidentally accelerate to 50mph while you're trying to reposition it in the campsite.
gbopp
The Keystone State
Posted: 09/02/21 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky
time2roll
Posted: 09/02/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
As a rental or a bit larger for full time I really like the concept.
675w Solar pictures back up
Posted: 09/02/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah that’s a great idea…..
Paging Reisneder….
2017 Heartland Torque T29
Skibane
San Antonio, TX
Posted: 09/02/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
Clicky
Oh, Lordy...The subfloor under the trailer is completely filled with batteries - 1300 pounds of them.
Bobbo
Wherever I park
Posted: 09/02/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Isn't that what a Class C is? Or Class A or Class B, for that matter? A drive-able RV?
Bobbo and Lin
1320Fastback
Vista, Ca
Posted: 09/02/21 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see how a light duty electric truck will ever have any kind of towing range until the trailer itself is stuffed with batteries to either power the truck also or like this power the trailers wheels.
For now I'll keep my Diesel.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
