RV.Net Open Roads Forum: Safety Chains Binding Between Hitch Head & Trunnion Bars
 > Safety Chains Binding Between Hitch Head & Trunnion Bars
QCMan
Independent Republic of Horry
Posted: 09/03/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
If that was my rig I would have the chain attachment point moved back a bit. That seems to be where your issued are originating. It appears that you have several inches that you can move the attachment point before it gets close to the tongue jack.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
schlep1967
Harrisburg, PA
Posted: 09/03/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
An easy test for this idea would be to use some zip ties and tie the chains to the back of the welded loop. From the pics that would be at least 1 1/2 inches back.
Personally, I think you need another link or two in your chains. The extra length would keep everything hanging below the pinch points when turning.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
ktmrfs
Portland, Oregon
Posted: 09/03/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
do you have the HD snap up brackets with the extra gussett on them? If not you NEED them with the 1500lb bars or you WILL bend the brackets.
2011 Keystone Outback 295RE
Arn
Ottawa Valley, Ontario, Canada
Posted: 09/03/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I do have the HD bracket. It was supplied with the hitch & the dealer installed it. It's not the snap up bracket that is bending though, it's the flat hanger bracket & the cam.
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
carringb
Corvallis, OR
Posted: 09/03/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
It's the under-slung coupler combined with the forward safety-chain mounting. I think moving the safety-chains aft would fix the issue.
2014 ORV really big trailer
2015 Ford Focus ST
Fisherman
Angus, Ontario, Canada
Posted: 09/03/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Why can't you route the safety chains on the outside of the torsion bars. Then nothing will get pinched from what I can see in the photos.
hornet28
Muskegon Mi.
Posted: 09/03/21 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
As long as the chains are long enough I couldn't agree more. Where they are now is just asking for trouble
Arn
Posted: 09/04/21 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
hornet28 wrote:
As long as the chains are long enough I couldn6't agree more. Where they are now is just asking for trouble
That was the first thing I tried, too short. When I get home I'll be putting on longer chains so I can do just that.
Z-Peller
Oceanside BC
Posted: 09/04/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer manufacturer have attached those break away chains way-y-y too far forward on the trailer, that is the problem. Have new attachment points put on just in front of the anti sway stabilizers.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
Z-Peller
Oceanside BC
Posted: 09/04/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Picture won't post??….on edit: thank you moderator for posting my photo.
* This post was last edited 09/06/21 12:02pm by Z-Peller *   View edit history
