RV.Net Open Roads Forum: Tech Issues: white paper on SiO2 batteries
 > white paper on SiO2 batteries
pianotuna
Regina, SK, Canada
Posted: 09/03/21 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Finally found one. It compares Lead Acid, Nickel Based, Lead Crystal and Lithium Based Batteries chemistries.
https://azimuthsolar.ca/wp-content/uploa........tudy-of-comparison-of-characteristic.pdf
Regards, Don
profdant139
Posted: 09/03/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for locating that item and posting it!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
noteven
Turtle Island
Posted: 09/03/21 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks pianotuna
marpel
notapplicable
Posted: 09/03/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Ignoring the less than professional grammar (reminds me of an item manufactured in China with a manual translated into English by someone in China), it's a pretty interesting read.
BFL13
Victoria, BC
Posted: 09/05/21 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Not clear on how much they tested the SiO2 themselves or used reported data from somewhere else.
Interesting that they say to charge FLAs at least at 10% charging rate, but no more than about 25%. I have found that rv/marine 12s like low and slow under 10% as long as you keep doing that till they get to 16v. Otherwise it is a real chore trying to get them to full SG.
I have not been able to really use my two SiO2s in the camper since last December due to Covid, so they have just been floating except for a deep cycle test in July to make sure they were ok. They were.
I think I will move them to the MH to get a 6 batt bank for the winter and just go with a single 12 in the camper for the day-running it only does these days.
I agree with PT to wait till next year when you will have a chance to use them before spending the big bucks.
I see Azimuth still has 36 of the ones he got 50 of before Xmas, but he has jacked up the "sale" price some lately. Don't understand that! Shelf life is happening big time there! Would have thought the price would drop by now.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
3 tons
NV.
Posted: 09/06/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Per BFL, “I have not been able to really use my two SiO2s in the camper since last December due to Covid”.
BFL, Interesting, but AFAIK there’s not been reported a single case of LiFePO4’s getting Covid!!
3 tons
PerryB67
Lanesboro, Minnesota
Posted: 09/06/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I received this and a couple of other papers last winter. This is an old paper, as are the others I found, and does not include LiFePO, but it helps to dispel the arguments against SiO2.
Our Soneil 260 ah SiO2's are still running perfectly. It's amazing how fast they charge, much, much faster than our AGM's. It's still too early for me to give a wholesale recommendation though.
Enjoy,
Perry
2018 Escape 5.0
2019 F150 Max Tow, Max Springs, 3.5 EB Quad Cab
3 tons
NV.
Posted: 09/07/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
PerryB67 said, “ but it helps to dispel the arguments against SiO2.”
Maybe it’s slipped my fuzzy mind, but personally I don’t recall any *substantive arguments against SiO2, in fact, if my needs were like PT’s (say, a non-heated battery box, e.g. sub-zero temps) I too would consider SiO2 as a highly competitive choice…In the end, I’m quite sure you’ll experience no regrets with what seems a sage choice [emoticon]
*initial cost, but offset by longevity…
3 tons
PerryB67
Posted: 09/07/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
On another forum our choice was met by a few ridiculous arguments.
At least two insulting posts were removed by moderators and I received a couple of PM's, supporting my position, about the negative attitude shown. In the end I just left the Debbie Downers alone though.
From what I've seen so far the SiO2's were the correct choice for us.
Enjoy,
Perry
* This post was last edited 09/07/21 11:33pm by PerryB67 *   View edit history
StirCrazy
Kamloops, BC, Canada
Posted: 09/10/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
if you take the Li batteries specs right out of this comparison, I wont call it a white paper because it uses sales littiture as references in some cases. but it is a good comparison of agm, lead acid and Lead crystal. to bad they used a 20 year old Li tech in the comparison but thats the way to make the other stuff look better I guess.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
