RV.Net Open Roads Forum: Class A Motorhomes: Decals cracking!
 > Decals cracking!
mountainkowboy
Socal/NE Oregon
Posted: 09/03/21 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone removed the old cracking decals? What gets them off the best?
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
haste maker
alabama
Posted: 09/03/21 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have been told a heat gun & a scraper...but be very easy with the scraper, not to damage the paint...
Retried Teamster
2007 Allergo
noteven
Turtle Island
Posted: 09/03/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
I am.
I am using a product called VinylOff made by Crystal Tek.
If the decals are not cracked, use normal lift a corner and get as much off by peeling them back on themselves as possible. Then use the product to remove the adhesive. If you apply the product to an old but sound decal it seems to weaken it so it does not peel nice but not enough to scrape nice if that makes sense.
If the decals are cracked, apply the product as per the instructions to the decal. I am using a rag to daub it on and steel razor blades in a scraper to remove the decal material.
I cleaned the area after removal with a rag and alcohol.
I plan to polish the gel coat once I am done removing the decals.
fyrflie
Martinez, CA. USA
Posted: 09/04/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
When I did mine I used a combination of heat gun, plastic razor blades, goo gone and a rubber eraser wheel.
The eraser wheel worked the best and left the least amount of residue behind to deal with.
Remember, you may have some ghosting of the decals left after removal and may not be able to polish that out.
I chose to use the ghost images left as templates and painted the graphics back on using automotive paint.
It is simply a tedious job.
Good luck.
mountainkowboy
Socal/NE Oregon
Posted: 09/05/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info...I haven't started yet, but it's coming. They just look horrible. I know I'll have ghosting, as said it will give me a template for paint.
ronbiel
AL
Posted: 09/09/21 12:05am Link  |  Quote  |  Print  |  Notify Moderator
Heat gun plus a plastic blade scraper should do the trick.
keefr
Edmonton
Posted: 09/09/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
+1 on the rubber eraser wheel. They do a fantastic job and leave virtually no residue. It's what the body shops use.
Never argue with an idiot - they drag you down to their level and beat you with experience. - George Carlin
TxGearhead
Posted: 09/09/21 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere in the world of you tube is a video of a guy painting OVER the decals. Looked good. Not especially difficult. Blue painters tape and rattle can paint.
I'll look around in my favorites and see if I saved it.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
TxGearhead
Posted: 09/09/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Found it...
https://www.youtube.com/watch?v=PSzhSks0PG4
and:
https://www.youtube.com/watch?v=8k0_pKfzm3w
Oldtymeflyr
Arapahoe Hills, CO
Posted: 09/09/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
We found that the rubber eraser worked well. Then some 3M Adhesive remover scraped with a plastic gift card, the flexibility of the card works well on fiberglass. To clean up the remaining adhesive, discoloration, and general oxidation, compounding with an appropriate liquid cleaner is necessary. I use a number of products, rubbing compound, 3M Perfect-It, and Meguires 67, which I use the most. Use a rotary buffing machine on fiberglass, I find that the orbitals do not work nearly as well. Gel Coat on fiberglass is different than paint. Get the speed up and watch the heat carefully, keep the machine moving.
Then to clean things up and make the MH look good, I use Meguires 67 which has a wax base as well and it does look good when done. I also use Fast Finish by Meguires, this is an easy to use product that produces a good result. I am experimenting with Meguires Ceramic Hybrid product, but do not feel comfortable using it on the MH with out more experience with it.
If you do not have a good buffing machine, it will take a lot longer and be more difficult to finish the removal.
Best.
 > Decals cracking!
