RV.Net Open Roads Forum: Class A Motorhomes: Got the MH weighed.
 > Got the MH weighed.
John S.
Valley of Virginia
Posted: 09/06/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
We weighed all the coaches at a rally and all of the single axles with a slide were overweight.
John
2015 Born Free Royal Splendor on a Ford 550
2018 Rubicon
Boo Boo a Mi Kie
42' 36' & 34 Foretravels sold
2007 Born free 24 sold
2001 Wrangler sold
2012 Jeep Grand Cherokee Overland sold
Susie Dolly, Lolly &Doodle (CKC) now in our hearts and thoughts
atsrmf
Indio
Posted: 09/06/21 08:48am Link  |  Quote  |  Print  |  Notify Moderator
My 27' Gulfstream weighed in at 11,100 lbs total, including fuel, water, and driver/passenger.
dodge guy
Bartlett IL
Posted: 09/06/21 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
well I`ve come to the conclusion that George is going on a diet before our next trip. I`m sure I can get rid of 1000lbs easy.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Yankee Clipper
Cairo, GA
Posted: 09/06/21 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, I don't think manufacturer's dry weight ratings are worth a hoot. It's really what you roll out of the chocks that counts. In my rig, the functional weight is 21,300, which is 700 under max gross...good enough for me. Toad is 3400, which is 1600 under hitch rating: what with EvenBrake, we're okay.
Junk in the coach and basement storage accumulates quickly. JMHO
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
dodge guy
Bartlett IL
Posted: 09/07/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Yes, a lot of storage is nice, but you can fill it very quickly!
Just doing a quick inventory in my head I can come up with 500lbs. And I know there is another 500 in there that’s unnecessary. 10 chairs? Really! Washers and Bocce ball I never play. Bags I only play once a year? And why do I have a 10 year old Xbox over the bed? I put it in there when we traded in the TT and never took it out.
Why do I have 7 pieces of outdoors cooking equipment? Small Weber charcoal grille, Black stone flattop, LP griddle, LP grille, LP table top stove, electric table top stove, and a tripod grille for campfires!
So out it all comes before our next trip. Then I will weigh it again.
Dale.Traveling
Newport News, VA
Posted: 09/07/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Pull the bikes off the back end and check the weight of the coach again. You only see an overall drop equal to the weight of the bikes and carrier but you'll also see a large drop of weight off the rear axle and a gain of weight on the front axle. The further back you get from the rear axle the greater the effect on the load on the rear axle. The chassis will act like a lever with the fulcrum at the axle.
Blue Ox has an easy formula to help potential buyers of motorcycle lifts to help determine how much weight the lift and bike will add to the rear axle. Using my gas coach with a 1/3 of the coach behind the rear axle adding 120 lbs of bike and carrier to the hitch receiver increase rear axle loading my 225 lbs.
Might not solve all your weight problems but will give a good head start. I will empty the coach each spring of everything and any item I could recall using the prior year doesn't go back into the coach.
Blue Ox Rear Axle Loading Information
2006 Hurricane 31D built on a 2006 Ford F53
willald
NC
Posted: 09/07/21 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
I can tell you from firsthand experience here recently, that you would be surprised at all the 'stuff' you accumulate over time in an RV, and how the weight of all of it can add up.
We just traded our Georgetown bunkhouse model in about a month ago for a smaller (but much nicer) unit, a Newmar 3014 (see signature). As part of that, we unloaded everything from the Georgetown, went through it all, and decided what to keep, put in the new Motorhome, and what to take out. It took several weeks, as this resulted in some extensive 'de-cluttering'.
Let me tell you, there was soooooo much stuff in that Georgetown that I had forgotten was there, that we did not need! I would guess we 'shed' a good 1,000 pounds worth of stuff that we are no longer carrying in the new unit. It truly felt like moving/downsizing to a smaller house, haha.
I weighed the Georgetown many years ago shortly after we bought it in 2012, and remember being well below the limits, then. I'm sure over the years that changed. I have not weighed the Newmar, yet, but I will soon, and will see where we are.
Anyway, good job on getting it weighed, even though what you found probably wasn't what you wanted to hear. As far as ways to slim down:
Unless you boondock for several days at a time, you can probably get by with a lot less water in your fresh water tank. That alone can shave off several hundred pounds That, and just go through all the various storage compartments, drawers, etc. and decide if you really, really need all that is in there. We found there is a lot we did not need. Do you *really* need enough plates, silverware, etc. to feed 8 or 10 people at a time? Do you really need the accumulation of 10 blankets and sets of sheets? You may well find like we did, that a lot of the stuff you have in there really doesn't need to be there.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
dodge guy
Bartlett IL
Posted: 09/07/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
I agree completely. I only filled the water at home because we have Lake Michigan water. Didn’t want the terrible campground water in the fresh tank. In fact when I got home I flushed out the lines and water heater so it won’t have that rotten egg smell next month.
mountainkowboy
Socal/NE Oregon
Posted: 09/11/21 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
We rolled through the scale at 6,600 front, 12,700 rear, and 5,500 on the trailer. 500 over our "hitch" weight" but since we have no frame extensions, I ran it. Ours has over 3,300 CCC on the sheet, wet. I doubt that I will ever be over weight. Heck, even maxed out on both axles I have to run the lowest recommended tire pressure on the 19.5's
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
crawford
Dandridge Tenn.
Posted: 09/13/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
when I had my c class it was even worse it was almost over loaded empty with 1 slide.
Change from a c class to a A class Georgetown 07 triple slide
