RV.Net Open Roads Forum: Tow Vehicles: Ram 1500 Long Tow Experience
Search only in Tow Vehicles
 > Ram 1500 Long Tow Experience
Posted: 09/07/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Bluhorn wrote:
While that trailer was hooked up it never saw 8th gear. Mostly stayed in 6th. I have the 26 gallon tank and that really needs to be upgraded to the 33 gal optional tank to extend range. Thats about my only gripe with the truck.Without the trailer I can achieve 24-25 on the highway.
You shouldn't expect to use the top gear or 2. Not a gripe, 7th and 8th gear are for your bobtail mileage claim, which seems a bit optimistic. Or quite optimistic actually.
Although you did say "can achieve", not "gets." So makes sense you could coax some great mileage under just the right set of conditions.
2017 Heartland Torque T29
Bluhorn
Sunny Florida
Posted: 09/07/21 11:57am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
What gear does your truck have? sounds like a good setup.
Dont know the ratios but its the 8 speed ZF.
1993 Dodge D 250 Cummins Club Cab
2019 Ram 1500 Laramie 4X4 Quad Cab
2006 Wildcat 28RK
2018 Sunset Trail 210FK
Kodi the Wonder Dog!
mkirsch
Rochester, NY
Posted: 09/07/21 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
What incident prompted you to make the statement about the oil?
dodge guy
Bartlett IL
Posted: 09/07/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Unless it was ordered specifically with the 3.90, it probably has the 3.21. With the 8 speed the 3.21 is OK, but if I were towing 5klbs plus I would want the 3.90. Mine is just a commuter truck so it will probably never tow anything. In fact it may be towed behind the MH eventually.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
