RV.Net Open Roads Forum: Camping World Service and Installation: Doghouse
Search only in Camping World Service and Inst...
Bch1548
Posted: 09/05/21 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
How do you access the engine in a class a motor home with a Ford v-10 engine with a doghouse in the cab between the driver and passenger seat?
IB853347201
Eastern Ontario
Posted: 09/05/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Either from below, or thru the wheel wells, or from above by removing the doghouse.
2010 Suncruiser
wildtoad
Blythewood, SC
Posted: 09/06/21 05:08am Link  |  Quote  |  Print  |  Notify Moderator
There should be several bolts on each side of the doghouse that secure it. They may be hard to find in the carpeting.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Near DVNP, California
Posted: 09/06/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Remember carefully how you removed the doghouse. They are harder to reinstall.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Edd505
Elephant Butte, NM
Posted: 09/07/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
About all that's done without pulling the doghouse is routine maintenance. Even from under mine work, learn to pull the doghouse. After it's done a couple times you won't be afraid of pulling it. Watch the bolts holding it down they MAYBE different lengths so need back in the same holes, only if different. Lining it backups really not an issue, a Phillips screw driver will help aligning it two's better one on each side. Get a bolt started and more to the other side, same routine. With two started the rest should drop in. (Prior Ford/Lincoln/Mercury mechanic - yes it's been awhile but mechanics don't change)
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
