RV.Net Open Roads Forum: Class A Motorhomes: Gassing Your Gasser
 > Gassing Your Gasser
bgum
South Louisiana
Posted: 09/06/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
As noted above Costco is a good choice also due to their design. I haven't found Sam's in this area well designed. In fact they can be tight entering or pulling out. Costco is designed more like a truck stop but dedicated to fuel only.
dsisemore1
Home
Posted: 09/06/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
38’ gas rig towing a Jeep. Never had a problem. Use either RV friendly stops at Flying J, Pilot or others. Other option any station with dual pumps, use either outside lane depending on which side your gas cap is on. I pull all the way up to the front pump and use the back pump to fill up.
Alex and Tee
Jacksonville , FL
Posted: 09/06/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Hadn’t thought about Sam’s as we are members there.
My gas tank is in the rear but on the drivers side opposite the roof ladder. Wish they had put it on the side. I had to actually put my drivers window past the front pump so I could reach it with the rear pump. I’m sure after a few trips under my belt and it will be old hat.
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
wanderingaimlessly
Buggs Island lake
Posted: 09/06/21 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
It's been a while since I was there, but there were several larger gas stations on US 1 in Florida City and Homestead that would be preferable to most down in the Keys.
Land on the islands is at premium so lots tend to be tight. Gas up before you cross over from the mainland, easier and cheaper.
donkeydew
OR
Posted: 09/06/21 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
watch your tail swing,it is easy to clip a gas pump or pole as you pull out.
Up&DownDeCoast
Rockville, MD
Posted: 09/06/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Been to the Keys several times with our rig. 50+ feet long with the dollied toad.
Always fueled up before reaching the keys in Florida City. There's Citgo station about 1/4 to half mile beyond the final expressway exit on US1. Its just after E.Palm Dr on the right after the Wendys. Easy in and out
On the way off the Keys we hit the Shell station just before the causeway in Key Largo right at the US1/905 split. Stay right on 905 and make a left into the station. Very easy in and out.
David and Wendy
2008 Winnebago Sightseer 35J
2021 Honda CR-V
Demco KarKaddy SS Tow Dolly
Dutch_12078
Winters south, summers north
Posted: 09/06/21 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
The key rule for refueling long rigs like RV's is to the extent possible, plan your exit before you enter.
Dutch
2001 GBM Landau 34' Class A
azdryheat
Tucson, AZ
Posted: 09/06/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Once you get more seat time you'll be amazed at the tight quarters you can get in and out of. Those A gassers are pretty nimble.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
rk911
DuPage County
Posted: 09/06/21 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Station with island pararallel to the building are normally easier to get in and out.
FlyingJ/Pilot stations are commonly higher price for fuel.
Other truck stops are very easy to get in and out even on car island. Love's and TAPetro are examples.
Get fuel early in morning or later in day to avoid high volumne.
FJ gas prices are very competetive. can't say about diesel.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
rk911
DuPage County
Posted: 09/06/21 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
this! best advice so far. i learned...the hard way..that's there's not a parking lot anywhere on the planet i can't get into. getting out with the toad attached is something else.
* This post was edited 09/07/21 08:28am by rk911 *
