RV.Net Open Roads Forum: General RVing Issues: Tire Failure
 > Tire Failure
Page of 5
1L243
Oregon
Posted: 09/06/21 07:44pm Link  |  Print  |  Notify Moderator
I still had the original tires on my 2017 Coleman 300tq Toy hauler.
I was planning on replacing them next year with Good Year Endurance ST Tires.
BUT
On a recent trip to Wyoming I was 200 miles into the days route with 175 to go.
I stopped at a rest area for a short break. This was the first trip with the new TPMS system for the trailer.
As we were getting ready to pull out a tap at the window, a guy towning a toy hauler to Sturgis said I think you got a problem with your trailer tire?
Sure enough...
A 12 inch chunk of rubber was missing. Tire was still holding pressure and temp range was normal. I suspect it just happened as we were pulling into the rest area.
It was 4pm on a Friday and we were 20 miles from a Les Schwab dealer and 175 miles from a Good Year Dealer. Les Schwab won.
My original tires were D rated Constancy tires. Les Schwab's ST tire is a Tow Star E rated tire Yes they have a china stamp on them.
There was no time for procrastinating I needed the tires on.
I have had Les Schwab tires on my truck before and they do all my front end and brake work. They seem to be a stand up company
They got right on it and we were out of there in two hours.
We will just have to see if the ST Tow Stars hold up or not.
I always do a walk around before setting out and saw nothing with the tires but in the future and will be doing a closer inspection before heading out.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
QCMan
Independent Republic of Horry
Posted: 09/06/21 08:13pm Link  |  Print  |  Notify Moderator
The tire told you it was aging out. A look at the date code would have shown how old they were. Probably made in mid to early 2016 would be my guess. Going up a rating will give you a stronger tire. That tire would have heated up as soon as you got back to highway speed.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
aftermath
Washington State
Posted: 09/06/21 08:17pm Link  |  Print  |  Notify Moderator
Les Schwab is a very reputable company. If they stand behind their products then I think you make a good choice. Just make sure they are rated at or above you trailer's weight rating. Also make sure you check the PSI before each trip and keep them aired to the proper number. I am not and Anti-Chinese tire person on origin alone. There are just too many variables to consider.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Lynnmor
Red Lion
Posted: 09/07/21 02:03am Link  |  Print  |  Notify Moderator
I am an Anti-Chinese tire person. How much evidence does one need to understand the problem?
NamMedevac 70
Reno
Posted: 09/07/21 03:26am Link  |  Print  |  Notify Moderator
It is great we still have tire choice manufacturer locations to choose from. No so with many other RV and vehicle product parts.
JIMNLIN
Oklahoma
Posted: 09/07/21 07:21am Link  |  Print  |  Notify Moderator
I do a pre trip tire inspection each day when were on the move but I also use my old tire thumper and a visual every time I stop the rig and get out of the truck for fuel or potty break.
The tread on that tire looks ballooned...and can be from tread delam. Typical older tech ST C/D/E poly tire that sat most of its life.
My 2 year old pre owned '97 32' 5th wheel trailer came with new ST225/75-15 D Marathons on 6 lug wheels.
Back then I didn't use ST tires on my service trailers so I sold the set (4) to a neighbor for his farm trailer.
Went with 16" 6 lug wheels and BFG Commercial T/A LT215/85-16 E at 2680 lbs capacity. The set ran for 7 years and 55k miles. The second set ran for another 7 years and 52k miles all with no issues.
Looking around rv websites I see the Endurance...Providers...Carlisle HD ST C/D/E tires seem to have much better service records than the older ST tires when they were all made in the USA and later made in china ST tires.
ChuckSteed
Mtn Home, Idaho
Posted: 09/07/21 07:22am Link  |  Print  |  Notify Moderator
going up a size to 10 ply E rated was a good move.. Where the tires are made is a mute point... Sailun S637 series are made in Vietnam and China and are some of the best RV tires on the road...
I am running a set of Les Schwab Geo Star 14 ply on my fifth wheel...on my sixth year with them... Made in China...
fj12ryder
Platte City, MO
Posted: 09/07/21 07:39am Link  |  Print  |  Notify Moderator
FWIW, there have been some issues with the Sailun tires made in Vietnam this year. I've read of at least two incidences of the tread separation. An unheard of problem with the Sailun. But in both instances the tires were made in Vietnam, and in early 2021.
I love my Sailun, and will most likely buy more, but informed choices are best.
Howard and Peggy
"Don't Panic"
phillyg
SWFL
Posted: 09/07/21 07:54am Link  |  Print  |  Notify Moderator
Me too, but the OP needed to get back on the road and had no other choice.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
JRscooby
Indepmo
Posted: 09/07/21 09:56am Link  |  Print  |  Notify Moderator
If there was any way to prove it I would bet that tire hit a curb or such in the last few thousand miles. Damage don't always show when it happens, but just like a note at the bank, it will come due.
Page of 5
 > Tire Failure
