RV.Net Open Roads Forum: Class C Motorhomes: What Is This?
 > What Is This?
TechWriter
On The Road
Posted: 09/06/21 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
This is under one of the dinette seats in a 2013 Thor Majestic. What is it?
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 gasser)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 gasser)
www.rvSeniorMoments.com
DISH TV for RVs
rlw999
Washington State
Posted: 09/06/21 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
That's the fuse box (and I think the Power Converter is in there too) -- press in on the top of the cover and it should release the latch. The latch on the one in the Cruise America unit I rented was broken and it was duct taped closed.
eHoefler
ozark mountains
Posted: 09/07/21 05:20am Link  |  Quote  |  Print  |  Notify Moderator
Power center, has your 110-volt breakers, 12-volt fuses, and convertor
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
PartyOf Five
Wheaton, IL
Posted: 09/07/21 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Agree with above. Ours has two latches you can turn with a coin in the top left and right corners and then the top half of the panel holds down on a hinge to reveal the fuses etc
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
IAMICHABOD
Sunny So Cal
Posted: 09/07/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
It is the fuse box,
Here's below the seat, shows the back of the fuse box and the storage tube for the table leg.
Former El Monte RV Rental
Buying A Rental Class C
TechWriter
On The Road
Posted: 09/07/21 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all! I think I've also noticed this box under some RV island beds.
 > What Is This?
