RV.Net Open Roads Forum: Tow Vehicles: Cummins engine barely starts
Search only in Tow Vehicles
 > Cummins engine barely starts
mexicanpiloto13
Phoenix
Posted: 09/07/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago we had an issue with a fuel cut off solonoid for our Cummins engine model 6C 8.3. It would it be difficult to start and I replaced the solonoid and it would start right away. now when we got to Fort Worth the engine would not start and barely kick over. Cranking very slow.. after 2 hours we got it to start and I'm wondering if it's just a bad engine battery. I did couple the coach batteries together with the engine battery and it's still kicked over very slow . We have a mobile mechanic coming tomorrow and I'm wondering if it sounds just like a bad engine battery. Voltage reads 12.8 in the coach but that could be a a surface charge. Any thoughts? It's been hard to start for a while, never kicking over fast. I hope it's not a sticky cutoff solonoid because there are none left in the US!
Ranger Smith
Wherever the rig is parked
Posted: 09/07/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Could be the batteries, starter or bad ground. Batteries need to be load tested. Did you ever change the engine batteries?? How old are they?? Clean the grounds from the engine battery
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX101D, Ameritron AL-80 Amp, Icom 7100, Yaesu FT-991A
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
wolfe10
Posted: 09/07/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Before spending $$$ on someone else, check both positive and ground connections between chassis battery and engine.
Also, while someone else is cranking the engine, monitor chassis battery voltage at the battery and then at the starter with your DIGITAL VOLTMETER.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
wing_zealot
East of the Mississippi
Posted: 09/07/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
How old is the starter?
Posted: 09/07/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
No fuel vs cranking too slow are most likely totally different issues.
2017 Heartland Torque T29
Posted: 09/07/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
To better describe, differentiate “kicking over slow” from “cranking slow.”
One says low voltage, or bad batteries or bad cables or possibly starter motor on its way out.
The other says it takes a long time to get fuel.
mexicanpiloto13
Phoenix
Posted: 09/07/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Original equipment. 1998. 126,000 miles. You have been very helpful.
jdc1
Rescue, Ca
Posted: 09/08/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Phoenix? Batteries don't last long in 120* temperatures.
Posted: 09/08/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
OP has stopped providing diagnostic breadcrumbs, so time to move on apparently.
Sounds like it’s a P pump ISC, so about as simple as they get and bulletproof engine (in a RV anyways) with as low of miles/hours on it.
Fuel, air and good power to the starter is all she needs.
mexicanpiloto13
Phoenix
Posted: 09/08/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for your help.A diesel mechanic came to the unit this morning said the batteries are sufficient although old. He recommends cleaning the terminals he thinks the starter solonoid is going out because there's a slight hesitation when engaging the starter. I have a call into Cummins to see if they have a solenoid or starter so I can have the whole package put on there I appreciate everybody's help.
