RV.Net Open Roads Forum: Tech Issues: Kohler 5CKM21 no compression in both cylinders
 > Kohler 5CKM21 no compression in both cylinders
Page of 5
Gjac
Milford, CT
Posted: 09/08/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Finally got to go camping last week, started the genset to heat lunch, it started right up, ran for no more than 10 mins then died. Would not start again. Checked fuel pump plenty of fuel squirted out, checked spark had spark but plug was dry. I noticed a broken wire to the fuel cut off solenoid at the bottom of carb bowl and reattached it thinking that was why the plug was dry but still no start and dry plug. Sprayed starting fluid into cylinder but not even a pop. When I returned home I checked both cylinders and neither had compression. What would cause both cylinders to have no compression? Of course my worst fear is a broken cam shaft or something serious, but I did not hear any noises when the genset died.
bgum
South Louisiana
Posted: 09/08/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Valve stuck or worse.
bgum
South Louisiana
Posted: 09/08/21 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Duplicate
Gjac
Milford, CT
Posted: 09/08/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Would a stuck valve cause both cylinders to have no compression?
enblethen
Moses Lake, WA
Posted: 09/08/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
You made it home!
I cannot find many drawings. Thing I did find is that you may have a "rubber" timing belt.
Timing belt
Would you check for any other model numbers on spec plate? Keep running into roadblocks on your number.
* This post was edited 09/08/21 01:11pm by enblethen *
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
bgum
South Louisiana
Posted: 09/08/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Did you pull the plugs to see if the pistons are moving up and down as they should? I know you said they were dry but did you check the pistons?
bgum
South Louisiana
Posted: 09/08/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Can't find manual on that model but some had a automatic compression release that were made to work with a spring and/or exhaust gear. Have you tried calling Kohler?
bgum
South Louisiana
Posted: 09/08/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
OK final thoughts are you need to check the valve lash and lastly it could be bad head gaskets. Anything else and it's going to get expensive.
Gjac
Milford, CT
Posted: 09/08/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I called Kohler, after 6 transfers I finally got a guy that seemed like he would help. Unfortunately he was not familiar with the engine. He said he would do some research and get back to me. He did not know why both cylinders would have no compression. Asked if it could be a broken timing belt he said he did not believe it had one. I found some web sites that talked about an ACR system but if I understand it correctly, if the spring fails the release faults to maximum compression rather than reducing the compression until it starts. You really can't see down the cylinders with plugs out, Bud suggested putting a plastic straw in the cylinders and see if it goes up and down when the engine is cranked. I will try that tomorrow and also will also try squirting some oil in a cylinder to see if the pressure goes up.
enblethen
Moses Lake, WA
Posted: 09/08/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Gary:
I found which engine it is.
Found it to be a "KT-17" used on many riding lawn mowers. Some look like vertcal shaft, but yours is horizontal, Correct?
Page of 5
