RV.Net Open Roads Forum: [SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
 > [SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
SlowBro
Posted: 09/09/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
I've stretched out Google (edit: and also checked a Lowe’s) but can't seem to find any replacement plug heads for what I am pretty sure is a 10 AWG extension cord which came with our used RV. (Edit: The jacket does not list the wire gauge.) Best I can find is 12 AWG. The plug head is missing the ground pin which causes it to slip out of the outlet too easily. I'm hesitant to cut the outer casing to confirm it's 10 AWG but the diameter is about 9/16ths of an inch which matches what I've seen 10 AWG cord is. And I don't want to cut the head to attempt to mate it with the common 12 AWG replacement heads because if it doesn't fit, it would ruin it.
So. Anyone know of 10 AWG replacement plug heads?
* This post was last edited 09/09/21 12:05pm by SlowBro *   View edit history
2010 Coachmen Mirada 34BH, class A, 34.75' long, GVWR 22,000 lbs.
God bless!
Posted: 09/09/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
NEMA 15A is a 15 amp plug should not neee 10ga
go to an electrical supply house Skip google and go to a sticks and bricks electrical supply house. If you can take the cord, or a couple inches of it, with you.
theoldwizard1
SE MI
Posted: 09/09/21 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Search for NEMA 5-15 or 5-15P
If really is 10AWG search for one that uses "clamps" to hold the bared wire.
Dusty R
Charlotte Michigan 48813
Posted: 09/09/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Look closely at the jacket of your cord. All cords, cables, wires, are labeled in size and type, most cords the writing/labeling is molded into the jacket.
enblethen
Moses Lake, WA
Posted: 09/09/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
You should be installing a 30-TT 30 amp cord body. cord body
Then buy a dog bone 30-15 adapter. Adapter
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SlowBro
Posted: 09/09/21 08:05am Link  |  Quote  |  Print  |  Notify Moderator
That was the first thing I did. Not there.
SlowBro
Posted: 09/09/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Not a bad idea. Also thought I might just use a short 14 gauge extension at the end, that short distance should be able to handle 15A, it’s rated for it.
SlowBro
Posted: 09/09/21 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I did that first before Google. Only 12AWG.
SlowBro
Posted: 09/09/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
No good on that search, only 12 AWG. I’m hesitant to try something not rated, not so much for the current draw as the size of the connector and jacket that it fits right.
CA Traveler
The Western States
Posted: 09/09/21 08:27am Link  |  Quote  |  Print  |  Notify Moderator
20A plugs are somewhat rare. My house has 2 and each is on a dedicated 20A CB. They were intended for golf cart charging. They will accept a 15A or 20A plug.
I receommend using 10 gage copper not copper coated extension cords with 15A plugs for RVs because 10 gauge has less voltage drop.
2014 Grand Cherokee Overland
Bob
