RV.Net Open Roads Forum: [SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
 > [SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
enblethen
Moses Lake, WA
Posted: 09/09/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Remember that you may not be able to run everything. Air conditioner may trip shore power supply breaker.
Hope it works out for you! Thanks for the update!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 09/09/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
SlowBro wrote:
wa8yxm wrote:
NEMA 15A is a 15 amp plug should not neee 10ga
go to an electrical supply house Skip google and go to a sticks and bricks electrical supply house. If you can take the cord, or a couple inches of it, with you.
Called an actual electrical supply house and aHa! Leviton 5266-C can support 10 AWG and it’s about $10.
Problem solved.
Interesting that the Leviton and Hubbell have the same part number.
675w Solar pictures back up
frankwp
Calgary, AB, Canada
Posted: 09/09/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Problem solved.
For some reason, wiring device part numbers are frequently the same or similar among different manufacturers.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
Posted: 09/09/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, SlowBro is slow. You said electrical supply house, I heard hardware store.
Problem solved.
Just bought a couple 15A replacement plugs at Homie Depot and used them on 10ga cord.
Not a problem.
2017 Heartland Torque T29
mobeewan
Hampton, Va
Posted: 09/10/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Could be numbered in accordance with an agreed upon standard or they are all purchasing them from the same source and reselling them.
