RV.Net Open Roads Forum: [SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
 > [SOLVED] Replacement plug head for NEMA 15A 10 AWG extension
SlowBro
Posted: 09/09/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
20A plugs are somewhat rare. My house has 2 and each is on a dedicated 20A CB. They were intended for golf cart charging. They will accept a 15A or 20A plug.
I receommend using 10 gage copper not copper coated extension cords with 15A plugs for RVs because 10 gauge has less voltage drop.
Yeah, it is 15A 10 gauge.
* This post was edited 09/09/21 08:45am by SlowBro *
2010 Coachmen Mirada 34BH, class A, 34.75' long, GVWR 22,000 lbs.
God bless!
SlowBro
Posted: 09/09/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I think I’ll slice the jacket lengthwise and look for wire labeling on that. Wish they had followed convention and put the label on the jacket.
pianotuna
Regina, SK, Canada
Posted: 09/09/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I drilled out the cord access to accept #10 wire. I used one of the plugs that works like a clam shell. It has screw terminals.
Regards, Don
enblethen
Moses Lake, WA
Posted: 09/09/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
many like this will accept the fine stranded number 10 wire. Cord body
A 20 amp cord body will not fit into a 15 amp receptacle. Blades have different configuration.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 09/09/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
The Hubbell plug will take #10 stranded wire with nickel plated clamp.
Cord Grip Range .230" - .720" (5.8 - 18.3mm)
https://www.stayonline.com/pc_product_de........asp?key=D6AC1C5C9D9C45019443C08AB1920082
Also available in 90 degree.
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 09/09/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Should have said that the individual wires do not have gauge shown inside cable.
Gdetrailer
PA
Posted: 09/09/21 10:49am Link  |  Quote  |  Print  |  Notify Moderator
SlowBro wrote:
I've stretched out Google (edit: and also checked a Lowe’s) but can't seem to find any replacement plug heads for what I am pretty sure is a 10 AWG extension cord which came with our used RV. (Edit: The jacket does not list the wire gauge.) Best I can find is 12 AWG. The plug head is missing the ground pin which causes it to slip out of the outlet too easily. I'm hesitant to cut the outer casing to confirm it's 10 AWG but the diameter is about 9/16ths of an inch which matches what I've seen 10 AWG cord is. And I don't want to cut the head to attempt to mate it with the common 12 AWG replacement heads because if it doesn't fit, it would ruin it.
So. Anyone know of 10 AWG replacement plug heads?
Standard replacement NEMA 15A rated plugs will generally accept larger than 12Ga wire as long as it is a clamping arrangement.
I just mated a cheapo Harbor Freight NEMA 15A plug to a piece of 10 Ga building wire and it fits and clamps fine.
Here is pix of the plug and wire..
Although, I wouldn't suggest using a HF plug for this application since you are using as an extension cord for your RV as they are pretty cheesy on design quality.
For your application, any of the name brand plugs found at Home Depot or Lowes should work fine.
Mike134
Elgin, IL
Posted: 09/09/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
NEMA 15A is a 15 amp plug should not neee 10ga
go to an electrical supply house Skip google and go to a sticks and bricks electrical supply house. If you can take the cord, or a couple inches of it, with you.
/\ /\ /\ /\ THIS!!!
you want something like this with a wire range of 18-10 ga
https://www.leviton.com/en/products/5266-cg
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
SlowBro
Posted: 09/09/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, SlowBro is slow. You said electrical supply house, I heard hardware store.
Called an actual electrical supply house and aHa! Leviton 5266-C can support 10 AWG and it’s about $10.
Problem solved.
SlowBro
Posted: 09/09/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Also a very good option.
