RV.Net Open Roads Forum: Truck Campers: Load center wiring
 > Load center wiring
Geewizard
WA
Posted: 09/09/21 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Here's my question: If one were to disconnect the negative cable from the battery to the load center (fuses, breakers, etc) AT THE LOAD CENTER, shouldn't one have no power to all the 12v devices?
And if one still has 12v going to those devices with that negative cable disconnected, doesn't that mean there's a wiring error? Such as the negative part of the circuit being carried by ground wires?
Just curious.....
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
2 Fullriver 100AH AGM batteries
Compressor fridge
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
jimh425
Western MT
Posted: 09/09/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I think it just depends on how the rest of the wiring was done. So, maybe not wrong, but at least a secondary path.
pianotuna
Regina, SK, Canada
Posted: 09/09/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If on shore power the converter will provide power to the 12 volt side of the rv.
If not on shore power, then try disconnecting at the battery end.
* This post was edited 09/09/21 09:37am by pianotuna *
Regards, Don
dhull
Some Lake Some where
Posted: 09/09/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget your truck battery is supplying 12 volts to your camper via the pigtail if connected.
Geewizard
WA
Posted: 09/09/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I'm not on shore power nor am I connected to the truck.
If I disconnect at the battery end, everything is unpowered as it should be.
I'm trying to find out if this is normal. I think it is because the negative terminal of the battery is connected to the frame ground as are the ground wires.
enblethen
Moses Lake, WA
Posted: 09/09/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
There is a wiring issue. It could be if connected to shore power, the converter is suppling 12 vots DC. If plugged into truck, the truck battery is suppling 12 volts DC. If not plugged into or shore power, the ground and neutral are connected together in the camper's 120volt distribution panel or fault in system.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
valhalla360
No paticular place.
Posted: 09/09/21 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Depends.
- Brakes are often direct wired to the battery thru the emergency breakaway switch, so it doesn't accidentally get disconnected while towing.
- Propane detectors, you don't want them accidentally disconnected.
- Solar often bypasses the 12v panel, so it can keep the battery charged when in storage.
- Inverters may have their own connection to the battery, so it can be placed close to the battery bank. Long runs of 12v at high amperage tend to have big voltage drop.
If you want to be sure everything is disconnected in storage, put in a disconnect at the battery that disconnects everything at the battery terminal.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BB_TX
McKinney, Texas
Posted: 09/09/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I would expect the battery ground cable to be connected to the frame as well as the load center. In that case, disconnecting ground from the load center would not disconnect ground from the battery.
Did you trace the ground wire to see where or how many places it is connected?
SoonDockin
Oklahoma
Posted: 09/09/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I have been going through my Arctic Fox wiring. The only other source of power I was seeing was from my 20 watt solar panel on the roof. It still manages to supply 12v in the shade but not enough amps to power anything. I disconnected it while working on it.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
pianotuna
Regina, SK, Canada
Posted: 09/09/21 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
No it is not normal.
