RV.Net Open Roads Forum: Truck Campers: Load center wiring
 > Load center wiring
Bedlam
PNW
Posted: 09/09/21 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
May be getting feeds from truck pigtail, AC converter or solar controller even with battery disconnected. I found some items don't run through the panel and have a direct line to DC with an in-line fuse.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
Fisherman
Angus, Ontario, Canada
Posted: 09/09/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
What BB TX said, the black, - cable from the battery is also attached to the frame and any items like lights, etc may be grounded to the frame.
BB_TX
McKinney, Texas
Posted: 09/09/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
It is also possible the ground wire from the load center actually attaches to the frame somewhere, not the battery. And the battery cable attaches only to the frame. The frame is ground.
Again the question is; have you traced the ground wire from both ends?
enblethen
Moses Lake, WA
Posted: 09/09/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
A ground wire from the shore power cable into the 120 volt load center should be attached to the frame and to the ground wire to the receptacles.
When using batteries and disconnect the negative cable from the battery, there is no path to power 12 volt devices.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Geewizard
WA
Posted: 09/10/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I have traced the negative battery wire from both ends and it runs directly from the battery to the load center. And yes, I do know and understand that the frame is ground. I don't find any bare ground wires inside the load center attached to the negative battery wire. They are separate.
This isn't a real big deal but more of a question of why the bare ground wires, which are bonded to the frame, are carrying a load at all.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
2 Fullriver 100AH AGM batteries
Compressor fridge
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
cewillis
Tucson, az, usa
Posted: 09/10/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Geewizard wrote:
I think it is because the negative terminal of the battery is connected to the frame ground as are the ground wires.
This seems right to me - distributed ground, not single point. Probably common practice. The only (and better) way is to have ALL the ground connections wired to a single point.
Cal
