RV.Net Open Roads Forum: Truck Campers: Load center wiring
 > Load center wiring
Bedlam
PNW
Posted: 09/09/21 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
May be getting feeds from truck pigtail, AC converter or solar controller even with battery disconnected. I found some items don't run through the panel and have a direct line to DC with an in-line fuse.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
Fisherman
Angus, Ontario, Canada
Posted: 09/09/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
What BB TX said, the black, - cable from the battery is also attached to the frame and any items like lights, etc may be grounded to the frame.
BB_TX
McKinney, Texas
Posted: 09/09/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
It is also possible the ground wire from the load center actually attaches to the frame somewhere, not the battery. And the battery cable attaches only to the frame. The frame is ground.
Again the question is; have you traced the ground wire from both ends?
enblethen
Moses Lake, WA
Posted: 09/09/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
A ground wire from the shore power cable into the 120 volt load center should be attached to the frame and to the ground wire to the receptacles.
When using batteries and disconnect the negative cable from the battery, there is no path to power 12 volt devices.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Geewizard
WA
Posted: 09/10/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I have traced the negative battery wire from both ends and it runs directly from the battery to the load center. And yes, I do know and understand that the frame is ground. I don't find any bare ground wires inside the load center attached to the negative battery wire. They are separate.
This isn't a real big deal but more of a question of why the bare ground wires, which are bonded to the frame, are carrying a load at all.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
cewillis
Tucson, az, usa
Posted: 09/10/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Geewizard wrote:
I think it is because the negative terminal of the battery is connected to the frame ground as are the ground wires.
This seems right to me - distributed ground, not single point. Probably common practice. The only (and better) way is to have ALL the ground connections wired to a single point.
Cal
Camper_Jeff_&_Kelli
Seattle
Posted: 05/23/22 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
If the negative is disconnected from the house TC batteries, no current will be flowing through the house system however, if you have hooked up the 7 pin plug, the negative wire is un switched and could complete a circuit if the key is on or switch is on completing the circuit via the truck battery. The house would be disconnected but truck power would be present. Try disconnecting the truck negative and that should cease all current flow.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
JimK-NY
NY
Posted: 05/23/22 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Geewizard wrote:
I'm not on shore power nor am I connected to the truck.
If I disconnect at the battery end, everything is unpowered as it should be.
I'm trying to find out if this is normal. I think it is because the negative terminal of the battery is connected to the frame ground as are the ground wires.
If you disconnect the battery, and the truck pigtail is not connected and there is no 120 v power, and you are not connected to solar, then it is normal that there is no power to any 12 volt device. If there were I would seriously wonder where the power was coming from.
The negative terminal of your battery might be connected to the frame. That is the way cars and trucks are wired. That is not the way my RV is wired. The frame is not used at all. In fact there is no metal frame, just wood. The negative wire runs to the power station. My solar is wired separately. There is a wire from the solar controller directly to the negative terminal of the battery. I also wired my NovaKool compressor refrigerator with a negative wire that bypasses the main electrical system and goes directly to the refrigerator. It was the easiest way to bump up the wire gauge.
mkirsch
Rochester, NY
Posted: 05/24/22 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Original post is from September, 2021.
trail-explorer
NM
Posted: 05/25/22 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
YEP. THis.
