RV.Net Open Roads Forum: Fifth-Wheels: manual retraction of slides
 > manual retraction of slides
ronharmless
The far side
Posted: 09/10/21 05:00am Link  |  Quote  |  Print  |  Notify Moderator
You may have a Schwintek slide, in which case you should read up on them. Clicky
BarneyS
S.E. Lower Michigan
Posted: 09/10/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
mookie wrote:
The electric motors all work at the moment. I am jsut trying to be prepared in the event that they dont... The underbelly is totally cover in coreplast .Have not found a hole where a crank would go .
The motor is visible right behind the slide out. All Sunnybrooks had their underbellies covered but if you look behind the slideout, you will see the motor and the shaft that connects the two sides together. The part you turn is on the bottom of the motor. You should also have a small crank to turn the motor with. It is black and is about 12-14 inches long and has a square opening in the end to fit the motor shaft.
My trailer also does not have a hole for a crank. You have to slide under the trailer to get to the motor shaft.
Barney
Not towing now.
