mookie
lisbon,ct
I have a 2006 Sunnybrook 31 BWKS . Not much material came with its purchase. If I ever need to manualy retact the slides I am wondering if anyone knows where I would get access to them. Thanks
valhalla360
No paticular place.
We had a 1997 Sunnybrook (mechanical screw system), on the passenger side was a hole and you could insert a crank and wind them in and out.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
laknox
Arizona
valhalla360 wrote: We had a 1997 Sunnybrook (mechanical screw system), on the passenger side was a hole and you could insert a crank and wind them in and out.
Better yet, cordless drill with a socket. :-)
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
BarneyS
S.E. Lower Michigan
On my trailer, the slide motor is on the bottom rear side of the slide out and can be operated either with the small crank that came with it or a electric drill/socket. It is attached to a long round bar that operates the opposite side gear along with the gear on the rear side.
You have to slide yourself under the trailer to access it.
Although our trailers are different types, I think Sunnybrook was fairly consistent in the use and placement of most things between models and years.
Barney
Not towing now.
valhalla360
No paticular place.
laknox wrote: valhalla360 wrote: We had a 1997 Sunnybrook (mechanical screw system), on the passenger side was a hole and you could insert a crank and wind them in and out.
Lyle
Better was just pushing the button on the wall.
Never had to use the manual method, so not really worth making a version that could be attached to the drill.
bob213
Fresno, CA
I read somewhere that they suggest unhooking the battery if you have to manually move the slides. I believe it was about back feeding the circuit. I'm sure someone knows more than me but it might be worth checking out.
agesilaus
North Florida
Lyle
Ditto, you ought to have a mystery crank that goesinto that hole
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
94-D2
Sutter Creek ca
On a hydraulic system there is a manual override mechanism you attach a drill/driver to and run it in. Same for the stabilizers as well. Got big problems if you are there however.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
It’s not what you’ve done that commands respect, it’s what you do.
Happy Campin’
Campinghoss@51
Windsor NC
On our 2003 Sunnybrook fiver the manual was underneath on the motor or by it. While in New Mexico our slide motor burnt up and I had to manually crank it in and out for the rest of our trip. It was repaired under warranty when we got back home. It would be much easier with a drill though.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
mookie
lisbon,ct
The electric motors all work at the moment. I am jsut trying to be prepared in the event that they dont... The underbelly is totally cover in coreplast .Have not found a hole where a crank would go .
Eric Lotreck
