RV.Net Open Roads Forum: Question about 12V charging on Jeep JL while flat towing
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Question about 12V charging on Jeep JL while flat towing
Thunder Mountain
Lost in the Four Corners
Posted: 09/09/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
I've flat towed a Jeep a TJ and a JK behind the MH with zero problems. Now I'm getting ready to flat tow my 2018 JL Jeep Rubicon. It is a whole new beast as far as the electrical system goes with it infamous stop/start system and two batteries.
I'm using the Cooltech wiring harness and a Brake Buddy II braking system. I'll power the Brake Buddy from the 12V outlet in the back cargo area since it is live all the time.
So, here is the question. Do I need an axillary charging system to keep the battery up for the Brake Buddy on the JL? Cooltech is pushing their charger. Is it a real need or just revenue enhancement? On the TJ and JK I never worried about the Brake Buddy draining the battery on a one day tow. If I towed for two or more days, I would just let the engine idle for ten minutes or so first thing in the morning to top off the battery.
__________________
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
sch911
Rochester Hills, MI
Posted: 09/09/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Otherwise the Brake Buddy will eventually kill the JL's battery. I reccommend simply connecting the charge line in the 7 way connector.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Tom/Barb
Oak Harbor, Wa
Posted: 09/09/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
We trailer the jeep. 2019 Rubicon..... we can back up.
CA Traveler
The Western States
Posted: 09/09/21 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I vote no since the BB has low usage for a day and as long there are no other drains. Some jeep models have the EPS running when towing and that answer would be yes.
My jeep has no loads when towed and the aux brake is air operated.
2014 Grand Cherokee Overland
Bob
dodge guy
Bartlett IL
Posted: 09/09/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Why not install a dedicated 12V outlet for the Brake Buddy charged from the MH?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
CA Traveler
The Western States
Posted: 09/09/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Connection to the toad battery is required for a break away situation. The voltage drop from the MH might be to great for proper operation of the brake.
Horsedoc
Dixie --- N. Georgia
Posted: 09/10/21 05:41am Link  |  Quote  |  Print  |  Notify Moderator
On a previous coach I ran a fused line to the Jeep battery to the coach battery. Nothing complicated and worked fine
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
our 2019 JL does not have a steering wheel lock, thus it doesn't need a key turned on to be towed.
we use a separate wire harness for lights on the jeep, there are many way to wire these.
dodge guy
Bartlett IL
Posted: 09/10/21 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
The Brake Buddy has its own battery just for this reason.
bighatnohorse
Gig Harbor - Cave Creek
Posted: 09/11/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Instruction manual:
The Manual wrote:
Problem: I’m experiencing frequent battery drain on my towed vehicle.
Solution: Battery drain can depend on your braking style and vehicle type. We recommend
recharging the car battery once every three days to maintain optimum battery
condition. Another solution is to install the Towed Vehicle Battery Maintainer
(#39332). This accessory item continuously maintains the towed vehicle’s battery
charge. Contact your local dealer or BrakeBuddy to order.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
