RV.Net Open Roads Forum: Question about 12V charging on Jeep JL while flat towing
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Question about 12V charging on Jeep JL while flat towing
CA Traveler
The Western States
Posted: 09/11/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
CA Traveler wrote:
dodge guy wrote:
Why not install a dedicated 12V outlet for the Brake Buddy charged from the MH?
Connection to the toad battery is required for a break away situation. The voltage drop from the MH might be to great for proper operation of the brake.
The Brake Buddy has its own battery just for this reason.
Thanks, haven't keep up with recent BB.
2014 Grand Cherokee Overland
Bob
dodge guy
Bartlett IL
Posted: 09/11/21 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. The only thing I know about them is when I helped my buddy install his that he bought in 18. It had the battery built in and needed a 12V supply to keep it charged. Since his focus needs the battery disconnected to tow we installed a dedicated 12V outlet that is only powered from the MH and only for the Brake Buddy. Has worked flawlessly for 3 years and over 10k miles for him.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
D.E.Bishop
Eagle Rock, CA
Posted: 09/12/21 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Please Dodge Guy, pray tell where the BB's battery? Should I be doing some sort of maintenance or adding water?
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
dodge guy
Bartlett IL
Posted: 09/12/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Scratch all that everyone! My apologies. As I was looking up the brake buddy, I noticed I was wrong. My buddy has the Blue Ox Patriot which has the built in battery.
Again I’m sorry for the confusion. Don’t know how I was wrong? I’m never wrong! [emoticon]
Y-Guy
Tri-Cities, WA
Posted: 09/12/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Thunder Mountain either system should work to power the BB2, and keep it from draining your battery. The plus to the Cooltech might be if it's all using the same umbilical cord vs having a separate line to deal with.
Now whether you need it or not, only way to know is to give it a test run and find out. Just make sure you have a way to charge the Jeep in case. I just can't imaging the system drawing that much power to totally drain a newer Jeep battery, sure maybe an old one that's already near end of life.
In all my reading about the various BrakeBuddy systems (select/classic/stealth) I never found one with a built in battery, they come with the charge cable and the remote sensor in the motorhome has a battery but that's all. There are none listed on the accessory page either.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
Alan_Hepburn
San Jose, Ca, USA
Posted: 09/12/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I thought I was wrong once, but I was mistaken... [emoticon]
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
