RV.Net Open Roads Forum: Truck Campers: WILL IT WORK
 > WILL IT WORK
RV Jim
Palmyra, Pa.
Posted: 09/09/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone,
I am looking to possibly buy a 1997 Jayco Sportster 9 1/2.
My question is, I have a 2008 F150 Super cab 2 wheel drive and a 6.5" bed, will this camper ride OK on my truck?
Thanks in advance,
JIM
jimh425
Western MT
Posted: 09/09/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
We need to know the weights, but my guess is not. A 9 1/2 TC is probably in the neighborhood of 3000 lbs or more. Probably way over the tire/axle rating of your truck.
In comparison, the highest rated 150s at most usually carry stripped down 6 1/2 TCs.
joerg68
St. Ingbert, Germany
Posted: 09/10/21 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Probably not.
With a 9.5 camper on a 6.5 bed, all of the camper weight will likely go to the rear axle.
Weigh your truck with a full tank of gas and all passengers that you plan to carry while camping, otherwise empty. Remove tailgate if you like. Get individual axle weights.
Find axle ratings on door sticker.
The difference between the stated rawr and the actual empty weight on the rear axle will give you an idea of the actual carrying capacity.
Note that any stated "dry weight" of the camper will be very far off the actual weight.
Truck Camping Lesson #1: once weighed, everything is heavier than you thought it would be...
Geo*Boy
Unknown
Posted: 09/10/21 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Long bed camper on a short bed truck and the weight of the camper is a BAD combination.
MORSNOW
Mountain Home, ID
Posted: 09/10/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Way too much camper for your truck, it will easily be in the 3,000 lb plus range so a HD 2500 or 3500 series truck.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
Posted: 09/10/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Negative ghostrider.
2017 Heartland Torque T29
jdc1
Rescue, Ca
Posted: 09/10/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
It's not worth finding out.....
BradW
Mayor of Flat Rock
Posted: 09/10/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Ditto.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
cewillis
Tucson, az, usa
Posted: 09/10/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
If that means 9.5 feet, is it the length that sits in the truck bed, or the total length? 9.5 feet in the truck bed is a pretty long camper, and definitely too long for a 6.5 bed (not even considering the weight)
Cal
Posted: 09/10/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Likely too long, yes. Definitely, no.
There are plenty of 11.5-12' long campers in 8' truck beds.
It's more dependent on the weight dist of the camper, structural integrity of the camper in the area that would overhang and whether the tailgate can be left in place to help support it.
Still too much camper for the truck, weight wise though.
* This post was edited 09/10/21 01:11pm by Grit dog *
 > WILL IT WORK
