RV.Net Open Roads Forum: Tech Issues: slide out
 > slide out
hogbob
S.F CA.
Posted: 09/09/21 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
Hello
I have a 2004 newmar and the rear slide comes in but stops about five inches from being flush . Thank you for any help. Kenny
Posted: 09/10/21 04:52am Link  |  Quote  |  Print  |  Notify Moderator
Best guess is somethign is blocking it... Inspect every place one part moves over another especially in the basement if it's a power gear
if it's an Accuslide the problem is harder to deal with
And the 3rd company I do not know anything about (Swientech)
HWH hydraulic should not have that problem
dougrainer
Carrolton, Texas
Posted: 09/10/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
2004 Newmar will be Newmar designed Slide motor and mechanism. There are a few things that will cause your problem. The Lock arms are bent and jamming the slide from fully closing. The Motor Intellitec controller is either defective or needs its amp draw pot adjusted. The motor itself may be defective and is drawing too many amps and causing the Intellitec motor controller to amp out and stop operation. If you have a slide cover, have you checked to make sure the slide cover is not rolling correctly and jamming the last 5 inches? Usually the Motor Intellitec controller for the rear slide on Newmars is located in the Mid bath area cabinets. ALL parts are Newmar supplied except you can get the controller from other RV suppliers. This link shows what the controller looks like. Doug
https://www.camperid.com/intellitec/cont........MHR0t7-ppQ-XvTHrBfVwfyAg9pBoCh1EQAvD_BwE
dougrainer
Carrolton, Texas
Posted: 09/10/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
This is a troubleshooting guide. Doug
https://newpar.newmarcorp.com/instance1E........99NEWMAR/html/images/SS2011SlideOuts.pdf
 > slide out
