RV.Net Open Roads Forum: Class A Motorhomes: Dirt Rod inline fuel pump instructions
 > Dirt Rod inline fuel pump instructions
juano
San Diego
Posted: 09/09/21 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I'm staying tonight on the property of the owner of a 95' Bounder on a F53 chassis that I want to buy, but was parked 10 years ago and has a dead fuel pump. I need to leave ASAP so I don't have time to wait for the shipping of the original intank fuel pump so trying to find a quick fix I found on this forum a post from the member 'Dirt Rod' saying that an inline pump is not only possible but better.
I sent him an email but the address is gone so I'm asking here if somebody can forward me the information by email: juanetchevers from the most popular email that starts with g.
Thank you!
ArchHoagland
Clovis, CA, USA
Posted: 09/10/21 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Inline Fuel Pumps
There are some in-line fuel pumps available on that site.
Good Luck!!
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
juano
San Diego
Posted: 09/10/21 12:09am Link  |  Quote  |  Print  |  Notify Moderator
ArchHoagland wrote:
***Link Removed***
Good Luck!!
That's not what I'm asking for but thanks for your time.
Dutch_12078
Winters south, summers north
Posted: 09/10/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Here's the info I used to install an inline booster pump on a 1995 Coachmen some years ago:
F53 External fuel pump info
* This post was edited 11/14/21 06:30pm by Dutch_12078 *
Dutch
2001 GBM Landau 34' Class A
juano
San Diego
Posted: 09/10/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
***Link Removed***
Thank you!
RLS7201
Posted: 09/10/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
The fuel pumps used in 1995 and earlier F53 chassis is a gerotor style pump and does NOT pass fuel well when not running. Same design as the old Ford oil pumps. An external pump may not work well. 1996 and later used turbine style pumps.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Dutch_12078
Posted: 09/11/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
juano wrote:
***Link Removed***
Thank you!
You're welcome and I hope the info gets the rig going for you. The one I installed worked well for saving a trip to the Grand Canyon and getting the motorhome back to upstate NY. One time saver I did at the time was to use a toggle switch temporarily attached under the edge of the dash to control the pump, switching it on just before starting the engine. I updated it to use the relay for automatic operation later.
I would give proper credit for the PDF and other info if I had any idea where I got it. If anyone claims it thanks for the assist! [emoticon]
juano
San Diego
Posted: 09/11/21 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everybody!
Can anyone confirm if I can split the dead in tank wiring and use the same wires fior the new external fuel pump? I'm trying to avoid losing time with new relays, fuses, connectors, etc.
bob@29154
Sumter, SC
Posted: 09/12/21 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I have been watching this post. I have a 1993 p30 with same problem. Would this fix work for my fuel pump? 1993 Itasca Sunrise.
juano
San Diego
Posted: 11/13/21 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
I already got the inline fuel pump, relay, wires and everything but my electrical skills are limited and seems that the instructions that a member of this group sent to me are incomplete as the manual mention 2 photos, one of the pump setup and other pf the relay setup but the relay photo is missing so not sure how to connect everything.
Maybe other member can give us a hand and I’ll let you know as soon as I successfully install it.
