RV.Net Open Roads Forum: Small Class A vs Large Class C
 > Small Class A vs Large Class C
TechWriter
On The Road
Posted: 09/10/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
We started RVing with a 34-foot Sea Breeze gasser in 2004, then upgraded to a 40-foot Newmar Class A DP in 2010 but sold it this year because it was just too big. We still want an RV, but this time around we thought we'd look at used, smaller Class Cs.
However, we wanted a rear island bed which is almost all cases we've found means 30 feet & greater. BTW, our budget is only about $35k and while RVs in that price range are few and few between, we've found that they are out there.
Anyway, after looking at a number of Class Cs that we initially liked, we're finding them sorely lacking when we compare them to similar sized Class As.
For example, I found a 32-foot Class A that had an island bedroom, 2 ACs (rare in Class Cs), levelers (also rare in Class Cs), and plenty of storage & carrying capacity.
Am I missing something?
2004 - 2013 Part Timer (2004 National RV Sea Breeze 8341 gasser)
2013 - 2020 Full Timer (2001 Newmar Mountain Aire 4095 DP)
2021 - ??? Part Timer (2001 National RV Sea View 8311 gasser)
www.rvSeniorMoments.com
DISH TV for RVs
Hank85713
Tucson, Az
Posted: 09/10/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
sounds as if the A's are what you are wanting. Most c's will not an island bed unless you get one in a slide. Also most c's lack big storage areas. We have a 28 ft winnebago, has a bed in slide for walk around (very tight on rear side, not a lot of storage space but adequate for what we have to carry.
A's to me are too big for us. When we were looking the dealers pushed the small A's but I drove a school bus of various sizes and any A to me would not necessarily be fun to drive in most areas. Yes ok in rural areas but thats about it IMO. too much tail swing to worry about is main thing. Many rv parks have narrow roads and that is another thing in itself. The smaller c is like driving a van but still has its share of issues.
So I would recommend a smaller A since that appears to be what you desire, ones in your price range out here are 15-20 years old or so. My BIL bought a 01 winnebago Adventurer DP just found out it has the cummins with the weak and cracked block and has had fuel issues which required new fuel pump. We suspect that is why he was able to get it cheap! He is also having AC issues with rear unit so no matter just get what fits your needs and happy hunting.
RetiredRealtorRick
Gulf Shores, AL
Posted: 09/10/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
I think you'd have a hard time going from ANY size Class A to ANY size Class C.
Having owned both, bear in mind the Class A cockpit becomes part of the living area -- not so in Class C's.
Also the tiny windshield with the cabover portion of the Class C hanging over it doesn't hold a candle to the panoramic windshields of Class A's.
Lastly, the jammed-up foot room of a Class C cockpit doesn't begin to compare to the foot room of a Class A.
There . . . and that's just the cockpit. You mentioned other things as well (dual vs. single AC, levelers vs. no levelers, etc.)
I know you'll make the right decision based on your needs & likes, but I kind of see the way you're leaning.
Happy travels!
. . . never confuse education with intelligence
pianotuna
Regina, SK, Canada
Posted: 09/10/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Hi TechWriter,
A small class A may be a heck of a lot nicer to drive than a 34 foot class C.
Mine is 28'5" and does have an island bed. I have no slides.
There is the kiss principle. The less tech, the less to fail?
Regards, Don
bobndot
Posted: 09/10/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
A 28' C with no slides would be my choice . I agree 100%, KISS !
If you think a small 'A' would be your cup of tea, I would rent one before you buy one.
As stated , the front window view is very nice on the class A. The problem for me is still having to drive it to your favorite spot.
People have to add all kinds of suspensions gadgets in order for them to not wiggle n waggle down the road.
Most of those kinds of floorplans all have multiple slides in order to make them appealing. That could mean a lot of extra unbalanced weight, combined with the short wheelbase and an entry level frame to support it all.
Be careful of RV's with light frames, they can pop large windows and front windshields if the frame flexes too much. This can occur when parking on an off level campsites or using the hydraulic jacks incorrectly. In some cases, it can be a recurring problem. Just do your homework before you make the investment.
wanderingaimlessly
Buggs Island lake
Posted: 09/10/21 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
A small gasser A should still work. I have a Winnie Vista, 27' island queen in a slide, second slide in the living area. And they also made a 30' model in the same years. 2010-2012 would fit your budget with some legwork. Vista brochure 2010
Janss
Sedona, AZ
Posted: 09/10/21 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think you're missing anything. We've had 3 Class C's and then 2 Class A's in 30 years. Don't think I'd ever want to go back to a Class C.
I actually think driving a Class A is easier, and especially when backing up...because it is all one width.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
AJR
Close to Madison Wisconsin
Posted: 09/12/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
It does sound like you are biased toward a class A. I had a 36’ gasser. I am now on my second used class C after the used class A. Maintenance is cheaper and service centers are more plentiful. Island beds are common on 28’ class Cs. That bed design can allow up to 100 cubic feet of storage under it.
I like the class C for three steps to get in or out. The cab over blocks midday sun when driving south making the cab cooler. At a gas station I just open the driver’s door & get out. I did add leveling jacks to my current rig.
2014 Leprechaun 290QB
Chevy 4500 6.0
2015 GMC Terrain AWD
Tal/IL
Central Illinois
Posted: 09/12/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
there are some very nice class Cs out there. But, I don't think I could give up the Class A basement storage. We carry a gas grill, Blackstone griddle,GMG pellet smoker, several tables, extra chairs, etc. etc.
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
Dusty R
Charlotte Michigan 48813
Posted: 09/12/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 27' Winnebago Itasca Spirit we bought new in 2015, it has a walk-around bed, and one small slide, and a large basement.
