RV.Net Open Roads Forum: Class A Motorhomes: ABS light.
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
What is required to reset the ASB light?
2000 Newmar - Cummins 8.3 - Spartan chassis.
Applying the brake 3 times with the key on doesn't work.
Disconnecting the chassis battery, doesn't work.
Using the trans control pad has no effect.
Is the spartan insite tool required ?
enblethen
Moses Lake, WA
Posted: 09/10/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't it require plugging a code reader into the Allison diagnostic port?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MountainAir05
New Mexico
Posted: 09/10/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
wheel sensor has excessive gap to the tone ring is one of the causes. You can try driving 15 mph and hit the brakes three time. If not do 30 mph and the same on the brakes. This comes from a friend who has your chassis.
* This post was edited 09/10/21 03:37pm by MountainAir05 *
sch911
Rochester Hills, MI
Posted: 09/10/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
The system has an active fault. Scan the vehicle. Find the fault. Correct it. Clear codes. Lights out.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
sch911 wrote:
Scan the vehicle. .
with what?
allbrandauto
maryland
Posted: 09/10/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
on most automotive vehicle abs lights reset on their own when you turn the key the abs module reads resistance on all sensors and soliniods if it finds one it doesnt like the light stays on if the problem is corrected when you drive down the road light will go off look at all the wheel speed sensors and see if you have a broken wire
enblethen
Moses Lake, WA
Posted: 09/10/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Are you in Oak Haebor? Call Powers up on Ault Field Road. They might be able to help/
OP has diesel with Cummins on Spartan chassis.
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know. "" Powers "" nothing in phone for them .
enblethen
Moses Lake, WA
Posted: 09/10/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Telephone number (360) 720-2233
My memory, which is getting bad, remembers they are just east of the entrance to navy base. Been a while!
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Now it is Barber shop.
